  • 1 year later...
Hi all,
Have a SARD carbon fibre gtwing for sale, SARD is one of the original makers of carbon GT style wings in Japan so these wings are very sought after in Japan.
$650ono
"bit dusty but condition is like new"
Did U end up selling this one bloke was wondering if it would bolt into stock holes or did u have to redrill
Cheers
Matt
I hate it when people do this and now I've done it too!!! haha.
Well I did a search and it was on the top of the list because 'noone' posted a few days ago...
