I am currently running 13psi on mine. I will be getting a tune pretty soon so might bump it up to 14psi, but I'm not willing to push it higher than that. Personally I am pretty stoked at the performance I am getting at 13psi so I don't feel the need to go much higher.
I have killed 2 X R34GTT turbos at 12 psi.
They don't make any more over a genuine 12 psi anyway, they heat soak the air so much you get detonation. So you have to retard the ignition timing and loose all the power you gained.
:) cheers :)
more boost doesnt mean more power
more boost means more power (well airflow) only when you are still in the efficency zone for the compressor wheel. past 12psi as others have said and its off the efficeny zone, so you just dial in more and more heat and it goes bang
90% of all stock turbos will blow at a genuine 15 psi if run there often.
It's not boost alone that makes them blow. It's boost and heat which makes the exhuast wheel delaminate.
Do a seach and see. This topic has been covered a 'few' times before.
Hey there,
So for all you guys that have had the turbo die on you, was the turbo ever subjected to continuous high heat levels, i.e., drifting, track racing, or continuous on/off throttle runs through the gears in short periods of time?
The R34 turbo's must have a small efficiency range if they start to die around 12psi, just seems low to me, and a very quick drop off. You'd be able to verify this on a dyno by looking at inlet temps at various psi.
The R33 turbo on my RB20 does make a fair bit more on the dyno at 1Bar (14.7psi) as opposed to 0.8bar (12psi), but it was on different dyno's, but using the same shootout mode. Inlet temps did not skyrocket either. R33 turbo's seem to be still good at 15ish- psi..... whereas R34's seem to go off at 12.
Fixxxer
Also shaft speed can be the killer. So just being on full song for a long long period can make it fail. Have seen a HKS 2530 fail with steel wheel so its possible to kill others also.
Fixxxer....
What power is the R33 turbs making on your Rb20?
Made 229HP@wheels at 0.82bar, held that all the way to redline I'm sure, with a ProfecA.
Think it made 247HP at 1bar, that was with the original owner, not the guy I bought it off. Might have been a few years ago but the graphs in the car.
Fixxxer
okay.
So thats 170rwkw at 0.8 bar
and 184rwkw at 1.0 bar.
the R34 Turbo on my car (which is an R34) made 200rwkw on 12 psi (0.8 bar) which is about 270rwHP
The R34 turbos are reasonably good for about 20 rwkw more on average than the R33 turbos due to their ability to flow much more through their exhaust housing.
BASS OUT
On an RB25 I wouldn't go over 12psi for the street. I blew mine at 13psi.
On an RB20 1 bar seems safe.
Just thought it would be funny to quote myself.
You can run more boost with any of these turbos if you have them fitted to an RB20.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
