hi Waz
there is a bit of a problem with that. definet 6 inch on the back parcel shelf but the front doors can be either 6 inch or a square 6x4 looking one
i personally had the 6 inch in front doors of mine but a mate has the other type and we have the exact same model car
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-195238
hi Waz
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-195251
you can make a spacer from MDF and fit it in the door and it will still fit under the factory grill.
That's what I did coz mine were 6x4 holes in the front. In the rear I used 6.5". everything fits under the factory grilles so nuffin looks expensive :D (good enuff for 130dB)
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-197447
i'm runnign a nakamichi 1000W 12" sub in the boot, alpine 200W 6.5" splits int he front (with spacers) both powered by a 4x200W Rockford Fosgate Amp, and a pair of JVC 6.5" in the rear running off the headunit for rear fill in. Had to put the fronts in with MDF spacers, the rest just bolted straight in.
Amp n subbie sit in the boot courtesy of a custom install/box.
Oh and there's an Esotoric Audio USA 1/2 Farhad capacitor just b4 the amp as well.
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-198782
if you're in melbz I know freeway car audio is havin a 50% off sale in a month or two (which is hwere I always get my gear from)
As for the front, I've got an AIWA MP3/WMA headunit with a flip front (flips inside out, ooks like a blank panel when u switch off the car). Also part of the system but currently sittin on my desk is my old PSOne, a DVD stacker and a 7" in dash screen.
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-198797
cool sounds ok
im running a kenwood double din in the front aloong with 6 1/2 inch 3 ways in the doors they are not 6 as before (my mistake) set of 6x9 2 ways on the back parcel shelf all speakers running from clarion 400wx4 amp then 2x12 in sub in the boot running from crossfire 1000d mono block amp
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-200668
Are the R32 front door speakers mounted on plastic pods? With the 6x4" or the 6" is it just the pod that is different or is the hole in the door panel different also? What would be the maximum mounting depth speaker I could fit behind the stock doortrim? What is the actual diameter of the hole to mount the 6" speaker?130mm?, 145mm?
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-224727
hey aybee
its not that hard to do
just have to make a new parcel self well i dont supose you would have to just depends on what look ya going for
you could just get some spacers and put them in that then run the carpet up to them
ill get some pics of mine and get them developed and put them up
have a look at the post DIY WEBSITE too if you have got anything to go up there
cya dudes :)
https://www.sau.com.au/forums/topic/11307-r32-speaker-sizes/#findComment-224738
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
