ok, so my car officially has no rev limiter, it goes all the way just past 8 grand (before i back off cos im scared she'll blow!). im 99% certain the taco is accurate as i hooked up a SnapOn diagnostic comp and it read the same. also went for a drive sunday and there doesn't appear to be a speed limiter. just wonderin if anyone has experianced this and they know why.
second thing, little while back went for a massive 1 and a half hour drive about an 1hr of hard driving and now im gettin a metal on metal sound like a scrap, periodically. sounds like its coming from the front left hand wheel. Possible break issue? i haven't experianced any lack of performance in any area since the noise started. so i got clues. any help would be great guys.
https://www.sau.com.au/forums/topic/113121-no-limit-and-wierd-noise/
My Old R33 had a HKS F con V Pro piggy back type ECU. At one stage I removed the F Con and just ran off what I thought was a factory ECU. Anyway it turned out that that ECU had no rev limiter or speed cut either and had obviously been modifed. I'm guessing yours had been modified the same for what ever reasons.
The metal on metal noise could be brakes, could be faulty shock absorber, could be your rim scrubbing on your coil over etc ... could be anything reall.y best thing to do would pull your wheel off and check for scrape marks as metal tends to leave an obvious mark.
the metal on metal sound is you running into the guard rails because you cant handle the extra rpm and speed.
Get a clue!
hhahah
gee thanks for that i'll keep it in mind..... yeah i was thinkin maybe the turbo as well, cos when i hooked up the manual boost controller to the actuater line there was a bit of oil run. now as far as i know with my limited knowledge, having oil in the turbo might not be best sign of a healthy turbo. But then again as i said before, haven't lost any boost what so eva, gonna get the brakes done early next week and see what happens. also yeah checked the ECU its factory doesn't look like its been modified at all, is there anythin to look for?
otherwise cheers at least i know im not alone.
i had a similer sound coming from my 32 a while ago, turned out to be a very thing peice of metal on my brake pads that gently rubs on the discs basiclly lets u kno ur pads are getting low. they call em squiller pads or sumthing.
an concerning ur ecu they may have just cut the wires, i kno The wire is yellow/green with a silver trace is the speed limiter. check this website out an read a few things on there u may be able to locate the problem.
www.rb20det.com
Sounds like your brakes are prolly just getting low after the thrash. If you look thru the wheel you should be able to see the outer pad. The bit between the backing and the disc is the brake material. Normally if a turbo is going you will hear a shrill noise when you come onto boost (terrible noise). They do tens of thousands of RPM so its too fast to sound like a scraping noise.
Hope i helped.
Deren
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
