hello from the usa.. i have a s13 hatch shell hanging around my shop that i want to go of the deep end with.. i am thinking rb20de or rb25de... i want to stay na as i have yet to see an na rb in the states.. i have looked through these forums and skylinesdownunder and see some interesting results.. just looking for some suggestions on starting point.. 20 or 25?
i am talking crazy like individual throttle bodies, header (extractors?), managment..
discuss...
benny
https://www.sau.com.au/forums/topic/113279-serious-na-rb-power-for-a-s13/
u dont get the 3 litre donk there in teh us of a do u?
bummer u
well
i would go with rb25de - not that much heavier than rb20, plus more power and torque (a bigger torque increase as bore size is the same - its only the stroke that adds more displacement)
indiividual throttle bodies would require custom fabrication i assume as i dont think anybody manufactures them for the rb25 (i think they r around for the rb26 tho)
exhaust side go some decent extractors and around a 2.5 inch exhaust
get some cams put in if u want - there are nismo manufactured cams for the rb25
management - use the standard ecu for 'run in' if u do any internal work (this includes head work) then u cant go past Apex'i SAFCII (cant think of any others of teh top of my head - somebody help)
just my info
its a shame you dont get rb30s over there. i have one here and its awesome.
i would do rb25 if thats what you can get.
but what would be better is to get rb26 and run it NA, run high compression 6 throttles.. damn that would sound so nice and be bloody fast :P
funny, i could have sworn the 20 and 25 had different bore sizes. last time i checked they did anyway.
as BADR33 said, go straight to the 26. rebuild it as a higher-comp motor up around 10.5:1 and make some nice headers for it. it will be the cheapest and best way to do what you want.
p.s. there's a reason you don't see many n/a RB's around.....
if there is a rebuild, 10.5:1 is WAY too low, more like 12.5:1 or higher :(
thanks for the replies... i know there is a reason you don't see many n/a rb's.. and i like a challange.. what are you guys rev'ing your rb30's too?
i am thinking i'd like to rev to 10k even.. and i'd like to make in the 200-250-225 kW range (around 300rwhp)..
i am leaning the way of starting with a 26.. so i start with hex throttles.. and i'm pretty sure getting it to rev to 10k wouldn't be too much of a stretch.. but it only has low compression.. i can buy a n/a rb25 and not have to open the motor..
benny
you will have to open the motor anyway to build something that will rev to 10k...
rb30s are apparently known to have harmonic balancer issues in the high rev range, so you may want to look into something there
ideally i believe the best NA RB combination would be an RB26 head with individual throttle bodies and trumpets, donked onto an RB30 block and with those light weight hypereutertic (sp?) pistons and like Maxx said 12.1:1 compression or even 13, depending on how much money your willing to pour in and the quality of your fuel...
benny
i can't see how can u rev a rb25 or even rb26 to 10k without opening the motor
more like 7k of rb25 and 8.5k for rb26
and the stock 10:1 and 8.5:1 compression will only give u around 200hp, that's at flywheel
either of them u will need a highly balanced, blue printed bottomend for the high rev, with custom forged pistion to bring the compression up.
u will also need some cams to make sure the engine will make power up to the built redline
plus hd valve spring + more
even with such a motor, i still doubt it can pull low 200rwkw
might need to throw in some giggling gas too to reach yr aim
so 10k is asking too much of a stock motor..? i wasn't thinking so based on 9k being on factory tachs and nismo versions for gtr's having 10k.. i know just because the number is there doesn't mean the motor will go that high.. but i would think it could get close.. i know of a couple "project" gtr's over here that i know rev to 9.5k with out having opened the motor and those cars are all still seeing boost..
if you want high revs go rb26 and ballance the internals, light flywheel and billet crank pully.
my rb30 has been ballanced and revs smoothly up to rev limiter at about 7200rpm.
yeah rb26 head on rb30 bottom end would be awesome as the rb30 has very good torque all the way through. have a look at my dyno results for mine. thats with rb25 head.
whatever the redline is on gtr then you can rev it to that then. but its all at a risk. if i was to do that i would want an r33 gtr motor and run N1 oil pumps and stuff.
for your power aim its not gona be cheep. you will need lumpy cams. ported and poilishd head. custom high compressoin pistons mb.
in the end its up to you. none of this has really been done as people just decide that they want max power so they go boosted.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
