hello from the usa.. i have a s13 hatch shell hanging around my shop that i want to go of the deep end with.. i am thinking rb20de or rb25de... i want to stay na as i have yet to see an na rb in the states.. i have looked through these forums and skylinesdownunder and see some interesting results.. just looking for some suggestions on starting point.. 20 or 25?
i am talking crazy like individual throttle bodies, header (extractors?), managment..
discuss...
benny
https://www.sau.com.au/forums/topic/113279-serious-na-rb-power-for-a-s13/
u dont get the 3 litre donk there in teh us of a do u?
bummer u
well
i would go with rb25de - not that much heavier than rb20, plus more power and torque (a bigger torque increase as bore size is the same - its only the stroke that adds more displacement)
indiividual throttle bodies would require custom fabrication i assume as i dont think anybody manufactures them for the rb25 (i think they r around for the rb26 tho)
exhaust side go some decent extractors and around a 2.5 inch exhaust
get some cams put in if u want - there are nismo manufactured cams for the rb25
management - use the standard ecu for 'run in' if u do any internal work (this includes head work) then u cant go past Apex'i SAFCII (cant think of any others of teh top of my head - somebody help)
just my info
its a shame you dont get rb30s over there. i have one here and its awesome.
i would do rb25 if thats what you can get.
but what would be better is to get rb26 and run it NA, run high compression 6 throttles.. damn that would sound so nice and be bloody fast :P
funny, i could have sworn the 20 and 25 had different bore sizes. last time i checked they did anyway.
as BADR33 said, go straight to the 26. rebuild it as a higher-comp motor up around 10.5:1 and make some nice headers for it. it will be the cheapest and best way to do what you want.
p.s. there's a reason you don't see many n/a RB's around.....
if there is a rebuild, 10.5:1 is WAY too low, more like 12.5:1 or higher :(
thanks for the replies... i know there is a reason you don't see many n/a rb's.. and i like a challange.. what are you guys rev'ing your rb30's too?
i am thinking i'd like to rev to 10k even.. and i'd like to make in the 200-250-225 kW range (around 300rwhp)..
i am leaning the way of starting with a 26.. so i start with hex throttles.. and i'm pretty sure getting it to rev to 10k wouldn't be too much of a stretch.. but it only has low compression.. i can buy a n/a rb25 and not have to open the motor..
benny
you will have to open the motor anyway to build something that will rev to 10k...
rb30s are apparently known to have harmonic balancer issues in the high rev range, so you may want to look into something there
ideally i believe the best NA RB combination would be an RB26 head with individual throttle bodies and trumpets, donked onto an RB30 block and with those light weight hypereutertic (sp?) pistons and like Maxx said 12.1:1 compression or even 13, depending on how much money your willing to pour in and the quality of your fuel...
benny
i can't see how can u rev a rb25 or even rb26 to 10k without opening the motor
more like 7k of rb25 and 8.5k for rb26
and the stock 10:1 and 8.5:1 compression will only give u around 200hp, that's at flywheel
either of them u will need a highly balanced, blue printed bottomend for the high rev, with custom forged pistion to bring the compression up.
u will also need some cams to make sure the engine will make power up to the built redline
plus hd valve spring + more
even with such a motor, i still doubt it can pull low 200rwkw
might need to throw in some giggling gas too to reach yr aim
so 10k is asking too much of a stock motor..? i wasn't thinking so based on 9k being on factory tachs and nismo versions for gtr's having 10k.. i know just because the number is there doesn't mean the motor will go that high.. but i would think it could get close.. i know of a couple "project" gtr's over here that i know rev to 9.5k with out having opened the motor and those cars are all still seeing boost..
if you want high revs go rb26 and ballance the internals, light flywheel and billet crank pully.
my rb30 has been ballanced and revs smoothly up to rev limiter at about 7200rpm.
yeah rb26 head on rb30 bottom end would be awesome as the rb30 has very good torque all the way through. have a look at my dyno results for mine. thats with rb25 head.
whatever the redline is on gtr then you can rev it to that then. but its all at a risk. if i was to do that i would want an r33 gtr motor and run N1 oil pumps and stuff.
for your power aim its not gona be cheep. you will need lumpy cams. ported and poilishd head. custom high compressoin pistons mb.
in the end its up to you. none of this has really been done as people just decide that they want max power so they go boosted.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
