I believe r34 lower control arms are the same as r33. I got one from a wreckers down in mexico somewhere. I asked for an r33 LH lower control arm and i received an r34 LH lower control arm. It bolted up just fine and everything else did as well.
How that helps your situation, i have no idea. Might help someone else though.
thanks for the replies. mexico is quite far away! (or u mean melbourne)
im actually going to be using the control arms on an s13. i have an s14 control arm on one side, looking for another one is proving difficult. hence why im looking for alternatives. id prefer the extra 10mm track or so the 14 arm gives.
do you have pics of your arms r33 racer?
Edited by juiceman
  • 3 years later...
Thread bump due to lack of available info about the OP's question........I need to know the actual length of a r33 compared to s13 and also What needs to be changed to fit them ( R33 arms ) to a S13 in relation to the castor arms.
hey mate, i got 33 lca on my 32. fits and uses the same bushing. they are slightly longer then the 32 items, gives wider track and you can get some epic lock. mind you i have removed bump stops and added lock spacers, not fully dialed in yet.
and i have no clearance issues with a 17x9.5
see all fits fine:
and some lock shots.
ps: ignore my unfinished body work :D
Edited by 32_Dave
R33/s14 arms are the same and around 10mm longer than s13 , but if you are going to use r33 arms you will need to drill holes for the swaybar links
other than that they bolt up fine as do castor rods
R32 is close in relation to the S13 and R33 is close to GTR.In short, no, won`t fit.
seriously mate... if you have no idea... then please do not post advice... this information is completly wrong.
OP, there are many threads on here and ns.com... do a search and all shall be revealed.
r32 is same as s13
r33 is 15mm longer and is same as s14.
s13 has different ball joints as does s14 but noone really notices from what i can see... im not sure if the r32 balljoint wont fit in the s13 hub but s13 will fit r32, but the actual control arms are the same.
if you have balljoint castor rods, they can bolt up to the r33 control arms, if you dont, you may need to re drill the castor rod holes to fit if you want it to move properly in its arc.
  • 4 months later...
I was thinking of putting some R33 or S14 LCA's into my R32.. and I was just wanting to make sure that S14 ones will be a straight fit and that everything will bolt up?
Also does it matter what S14 it comes from.. as turbo facelift ect ect
Or can I use R33 ones like 32_Dave used or are they not a direct fit.. as some people have said they need to drill holes ect
Edited by 30edR32
r33 and s14 would be the same arm and both should bolt up no problem, if ur car is low low you re-drill a hole higher then original to re-gain factory suspension geomatry.
ohh and here is the latest seup...
r33 arm + 20mm epicc !!!
and with a few secrets...
Edited by 32_Dave
And.. is this low enough to need a redrill
looks like it. if the arm isnt flat you need to get it as close to flat as possibly you will need to do some measuring etc. but its usually around 20mm or even as high as you can get the arm, you should also look into your rear geomatry, it will be f**ked at that height. check simons thread in DIY.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
