I have another 33 clutch to do tomorrow, an auto in a camry and a timing belt on an astra but I reckon I could squeeze in another one if you like.
Plus I'll be out too if you're out. I can't get a helmet from anywhere. My mate is not contactable so I was hoping that maybe I could borrow yours.
Anyone else willing to lend a helmet?
You're welcome to mine... and you've seen how boofy my head is too :P
Only problem is that you'll have to pick it up from Toowong, as I'm working late tonight and I have the car so Karen can't drop it out :ermm: If that's OK and/or you can't get hold of another one, you're welcome to use mine.
  • Replies 86
lights in the dashboard area (speedo, rpm, etc) aren't working.
looks as though i wont be going until these are fixed.
All dash lights are out? From memory they're on the same fuse as your taillights, check that, it might be a nice easy fix :P
you dont need dash lights to race at willowbank.
check your fuses and your dimmer, occasionally those things die simply cause compliance mobs use cheap shit.
though if your driving a fair way you may want to follow someone back into town, just in case there are any friendly constabulary patroling.(and most of the time there is at the very least a speed camera just past the Flinders View/Ripley overpass)
Nobody wants to loose double demerits.(or was that just for easter period?)
Timeslips 4 of my best but only 1 is OK really.
Practice OH practice.
Took my car to tuner yesterday and it was running sweet, so its all down to technique now.
By the way Hardcore have changed management now, Pete still has the dyno but it's a seperate business now and is going by the name of
"protorque" performance tuning, I recommend him highly,
some of the old staff are still there but all the salesmen are new and have no record of any previous work, so if you have any of those type of quetions talk to Pete and he may be able to help.0438876649
Nice work terry. I was almost certain I was going to pass you on the line lol. I was going about 30k's faster by that point. Bit disappointed in my result but I'm talking with my turbo supplier and hopefully I can have the smaller A/R housing donated in the name of research....rofl. Should shave a second and a half off my time.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
    • This is the only point I can access with any floor jack and my car is SUV height - What's the actual suggested alternative here? I have also driven up on blocks in the past, but lets say you have a problem and the car is on it's wheels already and can't be driven up/off anything? Not a huge fan of bits of wood being spat in random locations either (it hasn't happened, but what-ifs occur) Perhaps I would also really enjoy having a quickjack :p Time to google quickjacks.
    • The wires look to be a healthy gauge, more than I would think the pump needs. I guess another concern is if the FPCM will be happy with the extra current draw. I have heard they are a bit sensitive.
    • It will be fine. The real question is whether the existing wiring is fat enough for the current drawn by the bigger pump. The 342 is not that hungry, but it will be well worth pointing an IR pyrometer, or even better, a thermal camera, at the pump hat wiring when it is running, just to make sure. Or, you know, just touch it to see how hot it is.
    • Hi guys, Sorry to revive such an old post! The fuel pump in my M35 has finally given up, the car has been sitting for 3 years so I'm not surprised. I bought a Walbro GSS342 of Scotty some time ago, so I'll throw that one in. My question is, if my car has no performance mods at all, do I need really to mod the wiring to supply constant 12V? or will the new pump be just fine at the reduced voltage at idle? Thanks guys..
