hey people,
i have an r 33 series 2 that i purchased recnetly, and i am looking at upgradeing the turbo. my ideal power output at the end of the buildup would be atleast 300 rwkw to maaaaaby 350. i want a turbo that isnt super laggy as i dont want the car to be a one trick pony, id like a versitile ride. the two turbos that i am thinking of purchasing are a gt35-40 or a TD07. if anybody could give me any advice concerning the turbos or any suggestions at all in regards 2 my topic it would be much appreciated
cheers
ardie
https://www.sau.com.au/forums/topic/113447-what-turbo-should-i-get/
300rwkw - 10k before you even get started\
GT35 - if you want laggy... thats a good way to go on RB25.
If you dont have that money (10k), settle for 250rwkw now.
that will make a fast street car. Get you an low 12 @ the 1/4 mile.
300rwkw+ isnt cheap.
Then you break something (ie, stock motor) and its more expensive again
$$$ isnt an issue, as i always say, if your going 2 do something, do it right. im not just going 2 bolt on a big turbo and leave stock internals, i plan on making an engine that is reliable and powerful while also versatile. im lucky in that i have a reasonably large income and very low cost of living as iv deferred from uni in order 2 build up this car and get it over and done with within the year. (yes! im a geek and still live with my parents lol.....well atleast i live with them for the few months that they are in the country/state)
Edited by ardie
My 310rwkws owes me about 3.5g? whats the 10g for?
$$$ isnt an issue, as i always say, if your going 2 do something, do it right. im not just going 2 bolt on a big turbo and leave stock internals, i plan on making an engine that is reliable and powerful while also versatile. im lucky in that i have a reasonably large income and very low cost of living (yes! im a geek and still live with my parents lol)
Smart man.
I got a high mount manifold, and 50mm wastegate off ebay came with a shit turbo for 400bucks, manifold is tuned length stainless and is doing great, wastegate is working perfectly, went out bought a gt35r made an adaptor and put it on. Got 250rwkws at 10psi and I am currently sitting on 16psi for 310 rwkws.
First step buy a gtr... :P
rb25
$10,000 howto
ecu 1400 tuned
injectors 700
clutch 1200
airflow meter 350
turbo 2500
manifold 1100
fmic 1000
boost controller 300
exhaust 1200
leaves 250 for other misc stuff
gt30 or gt35r and a suitable manifold (excluding gate)
its still 8k then for a safe setup. and it will be laggy as all hell.
280rwkw is safe for standard internals. also it will be either bog the dog or wheelspin city, so average power will suck as it will come on like a freight train when it does. your much better off with more usable (lower) average power
a 260rwkw tpo 280rwkw setup will have more average power, less lag, less stress on internals and most likely be more fun to drive and faster overall as its power is more progressive and wont feel empty till it hits like 4800rpm which IMHO is lag city. a hiflow should come on just past 3k and be ideal as far as a quick street car
oh yeah i got suspension and brakes already 2 (car came 2 me from japan with a few little goodies) but u do make a good point, i just want something thats a little different, there seems 2 be alot of people in mid 2 high 200s but few with 300
Edited by ardie
There i always one ;)
Ok...
You are comparing RB25 with RB26... you better stop trying to do that or you gonna look a bit silly mighty fast.
How in gods name does that equal 3.5k? Have you done
Clutch? $1500
ECU? $1100/tuned/$1500
Injectors? $900
Thats over 3.5k and you havent even purchased you "ebay special" parts yet.
So suddently your 3.5k is now 7k... what a surprise that is.
I dont think i need to get into the whole e-bay "special" parts as have so many others.
Simple case is yours might work, the rest more than likely wont.
Ardie - if you seriously want a solid street performer look for a turbo around the 500hp mark
3037/3071 etc. GT30 (500hp versions). GCG hi-flow
This will get you close to 300rwkw, but the response & mid-range of the car will be second to none.
Best of all, they have been solidly covered on this forum time and time again
I had the biger 600hp GT30 on my RB25. It was great... but having since been in smaller turbod cars like Bass Junky with 250rwkw/GCG hi-flow.
Going for a little less (for a street performer) is the way to go in a RWD car
well you can't have both im afraid, there is no way possible you will 300 to 350 without lag and it being a trick pony.
as i said it will ever be lag city then wheelspin when its on or bog the dog, theres no inbetween as the housing and wheel will be just too damn big for that power output, so once it dials itself into effiency youll go from 80rwkw to 220rwkw in a few seconds (wheelspin)
hmm yeah im leaning 2wards the g3040 given the reccomendations, because the cars gonna b mainly 4 crabwalking, but i want something that can also own a few unsuspecting 5 ltrs. thanks alot 4 the opinios, and please keep them coming, they r reallly helping
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
