hey pplz, how hard would it be for me to put on my front & dump pipes into an R32 GTR. thinking of doing myself to save on some money. i done it for my R33 gtst but it seems so much easier on that compared to a GTR.
can anyone thats done it give me some pointers to make it quick and easier?. or shud i jus pay get it done :bomb_ie:
https://www.sau.com.au/forums/topic/113594-r32-gtr-exhaust/
pay someone, the dump pipes r a killer to get too, even with the motor on an engine stand, access to the nuts on the rear of the turbos is virtually impossible. turbos off job i'd reccomend and chuck those ceramic wheels out at the same time if u wanna avoid issues later and save 2x the labour. thats the beauty of a big single turbo, plenty of room :)
just a thought ;)
Brad
https://www.sau.com.au/forums/topic/113594-r32-gtr-exhaust/#findComment-2094475
just a thought ;)
Brad
LOL I removed my turbos to put the hks dumps on I bought and ended up Putting a big single on, the twin setup is messy and hard to work on.
Mate its a trubo out job.
Brad you got it buddy go the single
Mines the grey gtr
https://www.sau.com.au/forums/topic/113594-r32-gtr-exhaust/#findComment-2094490
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
