Theres an drag event coming up for SAUvic soon and I was wondering.....if i get some wide 15 inch drag slicks for the rear of my 33-t can i leave the street steel radial 17's on the front?
I heard ages ago that if you have slicks, they have to be on all 4 corners...any truth to this?
Can I bang the slicks on the back only and enjoy having traction for once?
Or am I destine to take on the 1/4 on my regular street tyres?
cheers
I've emailed heathcote park, but still no reply as yet... :(
https://www.sau.com.au/forums/topic/113743-tyre-regulations-on-the-strip/
Heathcote is not an ANDRA sanctioned track so you are probably ungoverned on tmixing radials and cross plys. But I've never raced at Heathcote .. anyone who has care to comment?
The ANDRA ruling is that you can mix radials on the front and crossply on the rear until you run quicker than 12.50.
But you really don't want to run radials and crossplies. Try it and you'll find out why in the top end.
Last time raced I had my Hoosier X-ply front runners on with the BF Goodrich Drag radials on the rear. It was amusing to watch the ANDR officials comb their regs to find a reason why I couldn't run like that. In short though-they couldn't find one. :) (because there is no rule on that one-and because it's fine as a combo)
As for the radial front/X-ply rear combo-Mr Blond is ,of course, completely correct.
The basic reason is that the radials don't much allow sideways movement of the car on the tyre, whereas X-plys do. What can happen is that the back of the car starts to move around on the tyre-bouncing from side to side, with the front staying put. This can get you into a positive-feedback condition where the bounce from side to side becomes more and more violent, eventually causing the car to sidestep and slide, or roll. Bad bad shit.
Think speedwobbles on a skateboard-but at 100mph plus in a car............. :(
Sean=-)
Just some further question, from a novice :(
Barely street legal tyres, such as Mickey Thompsons (sp?) and Nitto's, are still rigid enough to run daily standard/road front tyres, as these are still classified as a street legal tyre?
It is only when you go to a full drag tyre that you need to comply with the regs?
The only thing that governs the combination of front and rear tyres is the construction type.
Drag slicks, front runners and older (very old..) road tyres are of X-ply, or Bias ply construction. (have a siff about on the web for an in depth explanation and diagrams)
All other tyres are of Radial construction.
Nitto drag tyres, MickeyThompson radials(not the slicks), BFGoodrich Drag Radials and Hoosier Radials are all marginal for street use, but are still radials, and as such you do not need special front tyres to go with them (your normal street rubber is fine).
Hope this helps
Sean
so in a nut shell......I'd be best to look for a set of drag RADIALS for the rear for a little extra grip and to maintain balance of the car.
thanks for all the advise guys, much appretiated!! :)
anyone know where I can find CHEAP 17" drag radials in Victoria?
cheers
Hey mate I have raced at Heathcote heaps of times in my cars. You can run drag slicks on the rear and street tyres on the front with no problems up there.
I've been doing this on my Datsun and its recently gone 11.6/119mph with slicks on the rear and street tyres on the front and it has been straight on the track with no problems at all, top end included. Depends how fast your car is going to go I guess.
Heathcote Park owners have been on holidays the past week.
Put the slicks on and enjoy the G-Forces :(
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
