just because the map says where it it doesnt mean everyone knos where it is, im not really good with the north side/ city area so theres no need for attuide. i was just asking a question
Sorry bud, no attitude, I thought it'd be pretty easy to work out.
  • Replies 134
hey everyone, i have study the map and i hope i wont get lost (fingers crossed) but for the sake of a good cruise, can someone else take the lead as i dont want to take a wrong turn and see every other car go the other direction from me lol....
and no ending locaton has been organised.. so i guess we will go where we want on the night...
Sorry to pull guys but i cant make it. My car is sooooo not ready for next week dyno night...
I am in the process of putting it all back together atm...
The earliest i could get it into Matt Spry is next Thursday (the day of the dyno night) at 9am... So here is hoping that nothing goes wrong otherwise ill be stuck down the gold coast... LOL
sad to hear that col.... i would offer a lift, but sadly it looks like im going to have 3 people in car as it is... and i dont think 4 would fit to nicely
Serious question?
Why SAU?
whynot pulsar.org or something?
Not much stuff happens with the pulsar forums...
Just got my car back on the road after a long hiatus and wanted to take it out with some other predominantly turbo cars and have some fun.
Plus I live about 5 minutes from the airport :P
Anyway, seems like its only really Skylines so no worries anyway :(
There will be no "fun" had!
Please come say hi though.
By fun I meant checking out some nice cars, going for a drive, etc.
I ain't no FF Hoon :(
Well if I'm welcome I might pop round and say hi and checkout some of the awesome rides on here in person :P
OK, I'll answer your query
Directions for those that will use the Gateway
If you are coming from the southside using the Gateway, you need to take the East-West Arterial Road exit off the Gateway.
You then drive down to a roundabout (you need to turn right as if you were heading for the airport).
You will now go under the Gateway and you'll be heading for another roundabout.
Go straight through the roundabout (again as if you were going to the airport)...you should very soon see the DFO on your right hand side (I hope you do, as I've never been to DFO, but have seen it from the car).
Hope this helps,
Cheers,
Karen
thanks heaps mate, (smr33) which way do u think would be the easiest from the south side, im leaning towards the gateway.
Hey Col, if you need a lift I have an empty car. But I will be having a fairly early night as I start work on Friday morning at 5am.
We need your camera skills!!
PM your address if you are keen.
Dave
Gateway for sure :worship:
Paying the toll is worth it as then you don't have to stuff around with Riverside Expressway/Sandgate Road nightmare :D
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
