humm reminds me im on good behavior .. thus no GTR .. have to laze around in my gtst and chaser .. it is true tho if u dont do anything stupid eg. speeding.. hoon activity you wont get hasseled by cops.. drive slow like a grandma andthey leave you alone..
P.S if your friends used you for that they werent ever mates .. mates are ones who stick wit u no matter wat tell you its only a small amount ..
Edited by 53XYN
  • Replies 57
i went on 1 year probation, i bought the skyline 6 months into it, and i actually managed to do the remaing 6 monthw probabtion with ym brand new toy, (((almost getting caught liek every week)))
but yeah, we do stupid things, and we must live with it..
p.s talking aobut tools, i was in the Mcdonalds drive through today, the guy behind me in the passenger side got out, and said ""nice car mate, can u spool it"" i gave him a weird look and said nah, ill be right... i got the no need to be a jerk about it prick and he walk away....
Who does that?
Normally I don't say anything, but geez man, your grammar and spelling are absolutely atrocious! I'm not sure whether you're deliberately mis-spelling words or whether there is something else going on, but it hurts trying to read what you've typed. The term "taking a chainsaw to the English language" seems appropriate here.
Anyway, now that's off my chest I'll reply to your original post :( I can't say I've never done anything silly in or on cars and bikes, but one of my close relatives has lost his license a number of times, and was handed a 22 year suspension (2x absolute + 2 years), but this was reduced to 5 years after a visit to the appeals court. He did heaps of really stupid things, and I am amazed that he managed not to hurt/kill himself or someone else, but he has most definitely learned his lesson and now drives more sedately than my Mum... lol. He's kept his license incident-free since getting it back a few years ago :)
but in a drive through lol... and revhead if u are saying my english sucks, probably something to do with sitting in bed using a laptop with the lights off lol....
but seriously i dont fulled unglish
Lol nah was really aimed at the thread starter... there's a difference between some typos, and giving someone a headache :(
i did read from the start mate...
117 in a 60 zone...now i have goin over the limit....but f**k mate..double the legal limit?? what the f**k were you thinking you f**king moron..and you come in here like it's some sort of joke that you lost your license...
mate did i say it was a f**king joke NO. And as i said at the start I wood just like to let people no that i am not bragging and that i wish to hear about other peoples experiences...
f**k HEAD
Edited by gts-t 4 life
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
