If anybody wants copies of my John Laws collection I can make copies on my tape to tape thingy.
Neil.
If you can find someone with a vinyl press, maybe me or MAR55S (or whoever - I know there were a few DJss or ex-DJs here on SAU) can try it in a club one night - you never know what reaction it might get.
Failing finding a vinyl press, can you transfer to 8-track or reel-to-reel?
  • Replies 43
