hey guys,
i have just bought an r32 gtr skyline, and i gotta say it is an awesome car.
I have one problem with it at the moment and i was hoping you
could give me some ideas on it.
When i drive the car with alot of traffic, the gears become harder and harder to
get into gear without it crunching. If the car is just crusing it is all fine,
but in traffic it gets really notchy.
Now the clutch has been replaced and it engages really far down, as in you
lift your foot approx 1cm and the clutch disengages.
So what do you guys think it is?
could it be the gearbox fluid, or the clutch adjustment.
Any help would be great,
thanks
Todd
https://www.sau.com.au/forums/topic/114171-sticky-gearbox/
hey guys,
thanks
Todd
could be a lot of things.. my r33 gtst 5speed box was doin a similar thing, i thought lack of oil. i drained it and changed it, it had heaps of oil.. but more metal than oil came out!!! after i cleaned the metal shevings out, it seemed to stop
https://www.sau.com.au/forums/topic/114171-sticky-gearbox/#findComment-2103157
My gearbox was abit notchy when I got my gtr , changed the oil on the weekend to redline lightweight and it like somebody put in a new gearbox in , great stuff , thank to all the ppl on here who advised to use this stuff
Do a oil change c what happens , u will need a good 1/2in bar as the drain bolts are tight as
https://www.sau.com.au/forums/topic/114171-sticky-gearbox/#findComment-2103857
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
