Remember Anna what ever he reads on motsons dyno will be the same increase for the rest of us... In terms of a percentage... So if you ran 179 last night and you run 200 today and i ran 198 last night then in theory i would run about a 224rwkw area... Post up what he gets, will be interesting...
I dont want to get it done so I can come back and say see now I go to the top of the class, I just want 2 things
1. A more easily comparable result (Shoot out mode is the best we have) for before and after comparisons
2. A better graph to read...the scale they used for the power curve shows nothing, everyones was a flat line pretty much!!! And once again I want that for before and ater comparisons
So dont worry I wont be comig back claiming I beat anyone!!!
  • Replies 194
Posted Images
Unfortunately for me on my way home i blew a head gasket. Nothin major, just a slight little leak. So the second i noticed strange smoke out the back i turned the thing off and got it towed. should be back on the road soon :P
btw i was the guy with the piss weak rb20 silvia. haha
Col..1900N-m of torque..that's solid! At how much rpm did u hit max torque?
Any idea wot my final reading on torque was after the conversion? Got some ?? about the printed dyno graph...lol different from wot i usually see.
Anyway cant wait to see all the pics, videos and results from everyone that went on the dyno...
Cheers~ :D
Unfortunately for me on my way home i blew a head gasket. Nothin major, just a slight little leak. So the second i noticed strange smoke out the back i turned the thing off and got it towed. should be back on the road soon :D
So it was u how left coolant on the dyno...
Cheers~ :D
Pics are on page 8...
What was your final Nm reading j-boy???
If I knew you guys were racing to 250rwkw I would have run mine.
Col...I thought yours would have more torque than that...after all it is an RB25...mine's only a 20 and I make 620nm. There did seem to be some inconsistancies with that dyno though. Like Dan's 34...should have been making 175 at least. John's...properly tuned or not should still have cracked 220. Not saying it wasn't accurate, just a bit suss on it.
Col, yours should be somewhere in the vacinity of at least 500nm of torque.
Does not matter how the dyno reads... up or down... Impossible to say who dyno is perfectlly accurate...
You missed the point of the night dan...
It was to compair cars side by side on the same dyno... Plus to have a meet and greet... Bit if fun...
I dont care what kw and torque i had on their dyno compaired to others... All i know is that i drive a fat torque monster which will get me in enough trouble one day...
Anyways... I am only using the final figure divided by the diff ratio so it is dependant on thier dyno... But then i always knew i had heaps of torque...
Remember kw mean sweet FA... Its the torque that gets you down the quarter faster...
IMPORTANT
Can all of you who ran your cars pm me you figures...
I need the following
* Outright KW at the wheels
* Outright Torque at the wheels
* Speed at which highest KW was reached
* Speed at which highest torque was reached
As i have not got an email from them as yet and i want to wrap this up... So i can get onto the DVD....
I started it and the laptop crashed and ditched the clips... But i still have them on the camera... So here goes another hour of capturing and abother 20 gig... :D
DOU33....haha yeah guess i needed to clear some carbon....weird thing is that i just had a brand new 3.5 metalcat put in less than a mth ago... :
9krpm...thanx...guess its not too bad, my car was never built fer outright power anyway~haha dude if u were there u would smoke me with yer GTR! Hoping to see yer car on the dyno one day manz...My AFR was mostly on 0.85, dont know wot units this is on actually, but previous dyno i was running AFRs of about 11.7 Yeah catcha up soon yeah....maybe this weekend... :D
Yeah i went just to have a look at first n then decided to put my car on fer a run just to check how it's running...got to speak to a few people and was great getting to know new people, hoping to get to know more of u guys in the future. All in all, think it's something fer people to meet up n just have some fun. :)
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
