an oil cooler is a an easy thing to modify if needed to
they mostly come in various sizes with the pipe being one of two sizes,
if the standard one is too small get an adaptor barb
in terms of fitting, if the standard mounts dont work then some pieces of strip steel should suffice to attach it somehow
https://www.sau.com.au/forums/topic/114525-oil-cooler/#findComment-2109907
Worst case you will need a different threaded section for the sandwich plate, but i suspect they use the same thread.
You will have no issue with the length of the lines, and the core will likely need some custom brackets made up anyway as mentioned by usherly.
https://www.sau.com.au/forums/topic/114525-oil-cooler/#findComment-2110274
Cheers for your help guys. So you could be any cooler but the worst case is you would need to by a new thread, which wouldn’t be very costly anyway.
From looking at a lot of fitting i think that the sandwich plate is made up of 2 parts, a bolt that can be removed and the plate its self.
Look at the picture below
http://img171.auctions.yahoo.co.jp/users/0...045p4030016.jpg
The bolt and the plate or separated, so I assume that you could do this on most or all of the fitting.
https://www.sau.com.au/forums/topic/114525-oil-cooler/#findComment-2110587
