Ive got my rb30 block here all ready to have pistons bought for it however noticed on one of the pistons a marking of 10. Im presuming this means there are 10thou oversized pistons in there.
There is slight piston slap (movement in one piston) so im wanting to know what i can do with this block or is it more worthwhile to simply buy another one.
Sleeving it could certainly be an option however with the blocks around 150 bucks i dont see that being a huge issue.
https://www.sau.com.au/forums/topic/114634-rb30-how-far-can-you-bore/
If i remember it can be done 3 times. 10, 20 then 30 over.
Myself and Cubes went 20 thou over giving roughly 3.1Lt :whistling:
that sounds very good and means i dont need to throw out my block
will most manufacturers of pistons stock up to 30 thou over as i sem to find 10 being the limit on what i have seen? please give me links to correct me if you can
cheers for the information, certainly helps
ill take my block to the engine rebuilder tomorrow and get them to measure the pistons and see what they think. friends meant to be piecing the engine together for me howver isnt so confident on the amount of movement the pistons are making in the bores.
the next size of piston i can get is .5 oversize which would then be 20thou over meaning ive got plenty of room for movement. now to just figure out whether im going forged or na rb30e pistons and finding the part numbers (a small mission)
Edited by SirRacer
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
