hi every body just need some advice from people that know. iam running gt3040 powered rebuilt rb25 with gtr rods , wiseco forged pistons , tomei step 1 poncams and ported head. im running stock hydraulic lifters and valve springs. im wanting to rev the motor past 7000rpm to take advantage of the extra top end this gt3040 turbo gives me. whats a safe red line to have? thanks carl.
https://www.sau.com.au/forums/topic/114722-stock-valve-train-rev-limit/
Mine was set to 8000rpm.
That was knowing full well it woould see the drag strip, and it did a few times :)
Stock head aswell, not even cam'd
So i cant see why you cant do the same if its still making power.
You have the rods & better bolts, so DO IT
Does anyone know for sure or has had experience when valve float has started to occur in the 25's with whatever modifications they have had done?
Im curious to know if it happens often or not at all, i have yet to see anyone complain about 25det and valve float. Ive heard its a problem in neo25's cause their springs are weaker then the previous models, is that true as well if anyone knows?
Well thats good to hear. Just that were upgrading the springs to some stronger Isky ones for the 25/30 just to make sure..we will be running around 22-25psi outta the 3540. Just wanted to check incase anyone had run into such problems before.
Ok so someone has run into problems...well our redline on the 25/30 will be 7k due to standard harmonic dampner, so with the stronger springs we should be good.
What turbo may i ask were you two running R31Nismoid/turbo87?
Edited by r33_racer
I also ran into valve float at about 21psi. It started around 4k according to my tuner.
That was on an HKS t300s turboed stock cam'ed s1 rb25 making about 240rwkw up top. I've got my rev limit pegged at 7300 more due to worries about the stock rods than the valve train.
im running tomei poncams step 1 252 degrees duration at stock 8.5mm lift. now wouldnt running these cams with stock lift enable me to run similar rev limit to if i had the stock cams still installed??? if im going to run 22psi on hi boost do i need to restrict revs to 7000rpm or can i go to 7300rpm ? without valve float any ideas people???
If installing pon cams I'd recommend upgrading the valve springs to gtr items. With stock lift I'd say you should be able to hit 7500 but you'l certainly find out. Didn't you have a gt 30 with nissan exhaust housing before or am I getting mixed up?
Cheers
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
