Bad luck Mona. Will be interested to know if it's oil or fuel related.
Hows the oil in the sump look? Lots of golden flecks? May have just been a rod let go too. How does that look on the gudgeon (piston) end where it snapped off?Looks beaten on the lower part of the rod.
My advice for a daily driver though is RB25 with the right work and the right turbo. 26 is too lazy low in the revs and if you have a grabby clutch you will get some spin trying to get the thing going in the wet with RWD.
All the best on the new one and please post whatever you want in my thread below.
  • Replies 240
boost - 1bar
well confirm if the fuel pump is still working on not.. as far as i know she still is!!
Geoff - will do!! and yeah... losts of scrap metal and water droplets :w00t: Couldn't see the piston end.. only had a top view... so can't tell you what it looks like!
it's not that complex moonie..
look for the user CUBES. in his signature, he has a PDF file which is like a DIY rb30det guide.
go from there..
if you are going to be paying someone to fix your motor for you, might as well get them to do the 30 for ya.
probably cost less.
considering bottom end costs about $100
if you want forged goodies, then both bottom ends will cost the same.
small mod to the vvt oil line
small mod to the engine mounds and your done.
so to speak
Moanie who is having a look at the engine? like Geoff said it seems like the piston failed at the gudgeon pin which is pretty unusual? And we can't really tell if the rod broke as well.....and presumably when it all let go the piston mashed into the valves and head at eleventy billion miles per hour.
Normally pinging will blow out a ringland and you will loose a heap of compression before a rod or pin fails, so I'm wondering if there was some other cause?
moooooona
you had what, 250rwkw before?
on the same boost, on a STOCK (read: stock pistons, rods, crank, gasket etc) RB30 bottom end, you would have that power or more, with loads more torque earlier in the rev range, and would be more reliable.
If your head is ok, it would be the cheapest option for you.
if the head is gonesky as well, then you need to look at it a few more ways.
stock second hand rb25det from wreckers?
stock rb30 bottom end, with stock rb26 head with new rings and bearings?
I've seen rb26 heads complete with manifold, injectors and so on for about $2K
Justinfox is selling a pair of 2530's for $1K (one has s blown seal or something but thye were both built by GCG using HKS cartridge or something)
All bolted together you'd have some spastic amounts of power which a little girl like you could ever want.. :)
Not sure what sort of $$$'s you are looking at spending here or can afford to spend but think it all through and do the math before making a choice.
Finally... if you ever need someone to point and laugh at your misfortune, you know where to find me. well for the next 3 weeks anyway
hahahahaa... yes indeed i do!!
thanks for the ideas! i'll look into those options.. it really does come down to what i need to fix! but we'll see!! and i have no money at the moment!! jsut what i wanted to spend on rims!!! so i'll be going a cheapish option as well!! we shall see! :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
