Hi guys,
I am contemplating getting a set of Tein Super Streets for my R34GTT. Found two different model numbers:
QSN62-EZSS3 (supplied by Fulcrum)
GSN62-A1SS2 (supplied by Japanese distributor) 5K fronts, 4K rears
Can anyone enlighten me as to what differences there are if any? Or are they exactly the same thing with different model numbers for different markets?
I have confirmed both are for the ER34 specific.
Cheers,
Jon
https://www.sau.com.au/forums/topic/114847-tein-super-street-ausjap-spec/
Supposedly the aussie ones have extra heavy duty valving for aust. conditions.
However the extent of this i'm not so sure of, might just be one of those things where they havent done anything except change the label.
I am also definately interested in finding out what the specific changes are.
John, you know you want to be like me and get the Bilstein/Whiteline Kit!!!! :w00t:
Hi guys,
Cheers,
Jon
Hey Jon,
have u been quote on how much these are? iam also looking for suspension too..
mike
Hi guys,
Cheers,
Jon
Hey Jon,
mike
I've been quoted $1400 without camber tops for jap spec super streets. tossing between bilsteins and super streets. My problem lies with my driveway...if it wasn't for tht issue, it would be bilsteins all the way...
I've never had a consistent reply from Fulcrum. So I wouldn't trust what some guy from fulcrum said.
I would believe SK, and from what I've seen of the internal differences between the shocks, I'd be getting the bilsteins.
Edited by simpletool
So its same spring rates as the Super Streets from Jap but just with different oil valving levels?
Hmm I am too tossing up between the Teins or SK's Blistein/Whiteline kit. The teins are abit more expensive at about $1400 but I'm not sure the ones from Jap are suitable for Aussie streets.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
