Hey guys i just bought a R32 GTST and interms of engine mods it has a 3inch turbo back exhaust, a Cold Air Intake, a 500hp Boch fuel pump and a BOV. These mods were already on the car so i was wondering what the nxt step would be interms of reachin 180rwkw...... :angry:
could anyone tell me what coil packs do and if they would give ma a bit of power and yeh what the nxt steps i shoudl be takin were...oh and by the way im not prepared ot buy a bigger turbo or a another ecu atm so yeh jus pov mods at the moment lol :D
thanks
Daniel
https://www.sau.com.au/forums/topic/114929-r32/
hi mate congrats on the purchase, all i can think of is a front mount and a boost control i'm in the same boat not prepared on getting a bigger turbo just yet, my line is pretty much same as your as mods go apart from fuel pump, not so sure bout the coil packs i'd ho;d back on them until you upgrade your turbo, i'm planning on getting a adjustable fuel pressure regulater and a bosch 044 fuel pump soon and i think that will do me for awhile until i saved enough for bigger turbo,
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116177
you sure your gonna require a 044?
thats pretty big, and damn noisy, oh and external aswell.
have a run through here
http://www.skylinesaustralia.com/forums/in...howtopic=103095
see what they have and how much power they got.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116179
congrats on teh purchase!
- firstly give it a service: oil, oil filter, coolant, spark plugs, fuel filter, oxygen sensor
- then, put it on the dyno for an hour and get the tuner to see how healthy the engine is. they can also play around with your timing to get the most out of what you have got. plus you will get a power figure to see what the car is making
What are coil packs you ask?
they are coils within a little plastic pack that sit over the spark plugs. there's one over each spark plug. they generate a signal when instructed to do so, and pass this to the spark plug which creates a spark to ignite the fuel.
Will putting bigger coils generate more power?
Well it will generate a bigger spark, but this probably won't equate into much more power unfortunately
if you want to play around with the car a little more, i would suggest thinging of some of the following:
- front-mount intercooler ($300) and piping ($400)
- boost controller ($50) set to about 12psi (any more then 14psi can cause the turbo to fail)
That will give you a nice jump in power. they generally say 1psi raises power by 10kw when in the right setting (ie already have exhaust and intercooler)
good luck!
Warren.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116202
will only give a power increase if the current coils are not working.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116258
Next step is a fmic, and unfortuately thats the end of the pov mods. Turbo, injectors and ecu are next.
You will need a turbo to make 180 as the stocker doesn't like to play much past 160 odd. An rb25 turbo will do it though and they are cheap enough.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116555
fmic and 14psi boost should see close to 165-170rwkw if you are willing to test that sort of boost on stock turbo..
a few people have..
i think both roy and cubes ran this sort of boost on stock turbo and it didn't break..
no guarantees though..
180rwkw is not going to happen with stock turbo.
fmic kit from JUST JAP will set you back $500 or so.. see traders for sale section.
Dr Drift can also do retuned Stock ECU for about $400 or so I think.
now.. you say you don't want to change turbo but considering an Rb25 turbo will cost you like $350 these days, it's cheaper than both the above bits, but they are ALL needed for the 180rwkw you are after.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2116586
thanks heaps...i do have a boost controller (sorry forgot to mention) i boosted to abotu 15psi and started to shyt myself abit so i turned it down to about 10 lol so i decided to do what u guys said and look at a 33 turbo and yeh its onlly about 300 bux anyone know about how mani kws u can get out of it and how much boost it can handle ?
And as for the front mount ive been looking and alot of them, theres heaps of copy ones out there and they all claim to do the same as the hybrid ones but like yeh not too sure about that ;) Im thinkin i should just hold out for a lil while, not settle of crap, go for quality and buy the Hybrid 600mm yeh ?
cheers
oh and i knwo this isnt the place to post it but im afta a new steerin wheel so if ne1 got one and lives in melb let me know...cheers ( again sorry about postin this in here)
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2117990
hybrid copies are fine.
they are all the same except that HYBRID have plastered their name on the core.. it's the same core as the non marked ones, and comes from the same factory.
it'll do the job and do it well.
r33 turbo will make around 170-190 rwkw on about 13-14psi on an RB20 depending on dyno.
https://www.sau.com.au/forums/topic/114929-r32/#findComment-2118076
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
