Hey all just wondering if people can post up which speaker brands and models are direct replacements for the front speakers on a R33. Not interested in stuffing around and want to purchase a nice direct fit front speaker which will run nicely off my head set for the time being. Thanks im sure other people out there would be interested also.
https://www.sau.com.au/forums/topic/115030-r33-direct-replacement-speakers/
I have sent emails to both of you. Just case anyone else wants to know what we're talking about; I've posted the images below. Basically what we were discussing was that while 6" speakers are good drop in option, it is not too much further effort to install 6.5" speakers, an option that presents a much larger selection so far as the aftermarket speaker world is concerned. :)
I hope that helps you out. :dry:
Edited by Fhrx
I guess we should issue the warning that if you make your own speaker pods, check your clearances, as a lot of speaker magnets will hit the window if not spaced properly.
I bought Clarion 6.5" splits (about $200rrp), and they almost fitted perfectly. I had to bodge a little bit of it to make it sit inside the original speaker pods. If 7" speakers existed, they would have sat perfectly, but the pod was just too large for the 6.5's to go directly in.
I think it's been asked many times before, but there doesn't seem to be one guaranteed fit for stock pods. The originals were supposedly 6x4" or something crazy like that.
for a R32 they are 4x6. the rest are nissan 6.75".
excuse the dumbness when it comes to car audio but... i desperately need new front 6" speakers... where does the 'new' baffle need to go and where can it be purchased from? Also whats the deal with sound deadening?
Thanks guys,
Mark.
mark see the above images. if you just want to replace yours and aren't that fussed on installation then you can reuse the stock one. otherwise its a custom job. the baffles are made as needed.
(I should make a bunch of these things up seeing how I'm always asked for them..)
The blue was sound-deadening... it's just pyramid-shaped foam to disperse sound waves. (gets rid of echo)
The black stuff is sound deadening... again, it's best for high-end sort of stuff where you have the speakers and system to make the most of it.
The baffles everyone refers to, I beleive are the home-made pods that the speakers sit into.
With a little time and judgement, as Chris says, you can whack 6.5" speakers straight into the stock pod where your old speakers were.
If you want to be sure, take the pod out, and take it into the store that you are buying speakers from, and ask if you can sit a couple in the pod.
Chris: 6.75" eh?? That's what I was thinking with my estimate of 7". I know I can be pedantic sometimes, but the 6.5" look strange mounted in there!
Why muck around with 6.5's when you can, and i say this seriously, and you CAN with a lot of Modification to car, panels, doors, dash "simply" wack a set of these babies in.
http://www.usdaudio.com/products/wg-sets.php
With an 8" driver and compression horn, nothing comes close.
Hey ParaDizzle,
In all seriousness, if you want some really good speakers without a hefty price tag check out some VDO MPS1700. You WILL be surprised just how awesome these speakers are.
I can tell you from putting them in a few cars lately that they are absolutely awesome.
Currently I dont have a picture on file to post,
But they are
diam - 6.5"
watt rms - 90
sens - 91 db
Mounting depth - just right for an r33
Alot of dealers are just getting them in as they are a new product.
I would highly recommend a listen to these.
Cheers
Frx026
Hey ParaDizzle,
But they are
diam - 6.5"
watt rms - 90
sens - 91 db
Cheers
Frx026
Thanks for the reply,
whats the price tag on a pair of these?
also with them being 6.5" will they be a direct fit? or will it need some modification?
Cheers,
Mark.
They're 6.75", like some Pioneer models are. I think you'd have a far better chance of being able to screw them into the plastic pod where the originals were.
Mine were 6.5", and the screw-holes in the speaker were *slightly* too close to the inside hole of the pod. I made up a little bracket adapter and made some new holes in the pod. (that's what I meant about bodging it a bit).
If you're budget-constrained, and just want a *better* speaker than stock, check out the Pioneer ones. TS-A1780R is one model. It's 4-way, so you don't have to worry about mounting a tweeter anywhere. (although that is the preferred option, because the door-speaker mounting gives poor staging)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
