One of the first modifications done to a stock car these days apart from exhaust and rims, are pod filters. This is my first mod I have done to my fairly stock GT-R, and as such, thought I would write up my first tutorial.
After buying this kit for my GT-R, I found out that the entire manual is in Japanese. I searched all over the net for a tutorial on how to install it, but found nothing. As it turns out, it was fairly simple, but thought I would write something up for anyone who was in the same position as me :spank:
Item - Apex'i Power Intake (Apex'i #507-N001)
Time taken - 1-2 hrs (less after reading this ;) )
Tools - Socket set, flat head screw driver, 10 ml spanner.
Ok. This is what you got with a stock GT-R.
First off, unclip all the clips holding the top of the airbox to the bottom of the airbox. There are four to undo.
Next, you have to unbolt the top AFM from the side of the airbox. Use a 10ml socket on these.
Here you can see the first AFM unbolted. The yellow arrow shows where the second AFM is. Underneath the airbox.
I found out it was damn near impossible to get to the second AFM with anything. Here's the trick.
Get the longest flat head screwdriver you can find, and stick it under that big pipe, as the arrow shows. You have to undo the clamp that holds the second AFM to the rubber intake pipe. Also unplug the plug on the side. (Pretend the top of the airbox is still on at this point :ninja: )
After that fiddly bit, you should be able to grab the top of the airbox, give it a fair wiggle, and it should come out, with second AFM still attatched. :P
At this point, undo the clamp and plug on the first AFM and remove as well. Be careful not to lose the O-rings off the AFMs! (thanks saliya)
Next, remove the air filter and undo these three bolts -
and remove the bottom of the airbox. Too easy! Now you're left with this -
Now comes the fun part! Using the diagram in your installation manual -
Assemble the first pod, the one that sits closest to your headlight. Do the bolts that join the AFM and the metal flange up tightly, but finger tighten the rest, as they need to be adjusted in the car. You will find you will need to use a spanner on some of the bolts, as a socket would foul against the metal flange, so tiny turns with a spanner are in order! Also, the metal is quite soft, so be careful not to mark it too much.
Drop the whole thing in, and do up the two bolts that hold it to the chassis.
You should be looking at this -
Now put together the other pod. Be careful, the diagram is incorrect for brace number 7. It should bolt onto the metal flange on the OPPOSITE hole to the brace that holds the two pods together, NOT the next one over, as shown. That is, unless my number 7 brace was bent wrong, but I found it lined up with the hole on the chassis much better if I ignored the diagram.
Drop it into place. Put all the screws in the right places, as according to the diagram. Finger tighten everything, make sure all the black braces are in the right spots.
Once everything is lined up and in place, tighten everything up. Don't forget the metal clamps that hold the AFMs to the rubber intake pipes, and clip their plugs back in too.
And voila!
Now time for a CAI box!
Hope this was helpful!
:PBJ:
Edited by slimjim
https://www.sau.com.au/forums/topic/115034-how-to-install-apexi-power-intake/
There is a suitable Power Intake kit for Djetro version of RB26 also.
It may save some pipework hacking as you won't (or shouldnt) have to skip the airflow meter flanges
You mean this one?
Coz thats what I am looking at getting :)
where do u get the CAI box for this?.. im looking for one also
Apex'i used to make CAI boxes for these, but they have been discontinued as far as I'm aware. Looks like its a custom job now!
nice tute :mad:
I would put in the 'removing AFM' bit "be very careful not to lose the o-rings" because they're
buggers to replace if they get lost...
Regards,
Saliya
Thanks, added :P
  • 11 months later...
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
