One of the first modifications done to a stock car these days apart from exhaust and rims, are pod filters. This is my first mod I have done to my fairly stock GT-R, and as such, thought I would write up my first tutorial.
After buying this kit for my GT-R, I found out that the entire manual is in Japanese. I searched all over the net for a tutorial on how to install it, but found nothing. As it turns out, it was fairly simple, but thought I would write something up for anyone who was in the same position as me :spank:
Item - Apex'i Power Intake (Apex'i #507-N001)
Time taken - 1-2 hrs (less after reading this ;) )
Tools - Socket set, flat head screw driver, 10 ml spanner.
Ok. This is what you got with a stock GT-R.
First off, unclip all the clips holding the top of the airbox to the bottom of the airbox. There are four to undo.
Next, you have to unbolt the top AFM from the side of the airbox. Use a 10ml socket on these.
Here you can see the first AFM unbolted. The yellow arrow shows where the second AFM is. Underneath the airbox.
I found out it was damn near impossible to get to the second AFM with anything. Here's the trick.
Get the longest flat head screwdriver you can find, and stick it under that big pipe, as the arrow shows. You have to undo the clamp that holds the second AFM to the rubber intake pipe. Also unplug the plug on the side. (Pretend the top of the airbox is still on at this point :ninja: )
After that fiddly bit, you should be able to grab the top of the airbox, give it a fair wiggle, and it should come out, with second AFM still attatched. :P
At this point, undo the clamp and plug on the first AFM and remove as well. Be careful not to lose the O-rings off the AFMs! (thanks saliya)
Next, remove the air filter and undo these three bolts -
and remove the bottom of the airbox. Too easy! Now you're left with this -
Now comes the fun part! Using the diagram in your installation manual -
Assemble the first pod, the one that sits closest to your headlight. Do the bolts that join the AFM and the metal flange up tightly, but finger tighten the rest, as they need to be adjusted in the car. You will find you will need to use a spanner on some of the bolts, as a socket would foul against the metal flange, so tiny turns with a spanner are in order! Also, the metal is quite soft, so be careful not to mark it too much.
Drop the whole thing in, and do up the two bolts that hold it to the chassis.
You should be looking at this -
Now put together the other pod. Be careful, the diagram is incorrect for brace number 7. It should bolt onto the metal flange on the OPPOSITE hole to the brace that holds the two pods together, NOT the next one over, as shown. That is, unless my number 7 brace was bent wrong, but I found it lined up with the hole on the chassis much better if I ignored the diagram.
Drop it into place. Put all the screws in the right places, as according to the diagram. Finger tighten everything, make sure all the black braces are in the right spots.
Once everything is lined up and in place, tighten everything up. Don't forget the metal clamps that hold the AFMs to the rubber intake pipes, and clip their plugs back in too.
And voila!
Now time for a CAI box!
Hope this was helpful!
:PBJ:
Edited by slimjim
https://www.sau.com.au/forums/topic/115034-how-to-install-apexi-power-intake/
There is a suitable Power Intake kit for Djetro version of RB26 also.
It may save some pipework hacking as you won't (or shouldnt) have to skip the airflow meter flanges
You mean this one?
Coz thats what I am looking at getting :)
where do u get the CAI box for this?.. im looking for one also
Apex'i used to make CAI boxes for these, but they have been discontinued as far as I'm aware. Looks like its a custom job now!
nice tute :mad:
I would put in the 'removing AFM' bit "be very careful not to lose the o-rings" because they're
buggers to replace if they get lost...
Regards,
Saliya
Thanks, added :P
  • 11 months later...
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
