  • 3 weeks later...
  • Replies 80
Posted Images
Anyone got the part number for the dust boot which goes on the shifter to keep crap out of the shifter pivot?
Cheers
Aaron
Not sure of the P/N but just jap have them for $25
http://justjap.com/store/product.php?produ...=263&page=2
  • 4 weeks later...
  • 1 month later...
FULL RB25 NEO GASKET KIT 10101-AA525
R34 RB25 BOTTOM RADIATOR HOSE 21503-AA000
R34 RB25 TOP RADIATOR HOSE 21501-AA000
R34 RB25 FRONT HEATER HOSE TO BLOCK CONNECTOR 14075-04U00
R34 RB25 REAR HEATER HOSE TO BLOCK CONNECTOR 14075-AA505
R34 RB25 THERMOSTAT COVER 13049-AA000
  • 4 weeks later...
  • 2 months later...
R32 GTR Front Windscreen Centre Moulding / Retainer 72752-04U00 Approx $85 from Nissan (72811)
R32 GTR Front Windscreen Moulding / Retainer Set 72750-04U10 Approx $250 from Nissan - Replaced by 72750-04U60 (72810)
  • 1 month later...
  • 4 weeks later...
Part numbers for ECR33 Series 1
Radiator clutch fan (plastic blades)------------------------------9212110Y00
Front windscreen mould fastener (attached to body)----------7272522U00
Front windscreen mould (clips into fastener)-------------------7275222U00
Rear windscreen mould fastener (attached to body)----------7978022U00
Rear windscreen mould (clips into fastener)-------------------7975222U00
Standard thermostat---------------------------------------------2120042L06
CORRECTION TO THE ABOVE POST!
The radiator fan arrived today, looking an awful lot like an A/C condenser fan. They ordered me the wrong part, so.....
Radiator clutch fan (plastic blades)-----------------------------2106075T01
A/C condenser fan (blades only not shroud)------------------9212110Y00
  • 3 weeks later...
  • 2 months later...
Anyone know the part numbers for ECR33 series two headlights L&R?
Late reply, but for the Googlers...
Series 2 R33s have H1 bulbs for their head lights.
Not sure on high-beam bulbs.
Not sure on parkers.
Not sure on fog lights.
Could someone please let me know what parts the above three are? (I need them for my car :P)
  • 4 months later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
