Deal starting today 28\04\06 ending on the 20th\05\06
BEZELS
FOR ALL SKYLINES. R32 R33 R34 STAGER...And SIL & 180s
IF YOU GET A SET OF DIALS WE WILL CHUCK IN BEZELS FOR A MEAR $80(THATS THE FULL RING SET.)
IF SO MOVE TO THIS BUY:http://www.skylinesaustralia.com/forums/index.php?showtopic=113600
IF YOU WANT THEM WITH OUT GETTING DIALS THEY ARE $140 TO YOUR DOOR.
eg, r32 FULL SET OF BEZELS AND RING SET BRUSHED ALOY AND CHROME.
STAGER:
AND OTHERS. ie S13
PM ME FOR PAYMENT DETAILS :)
KEZZA
https://www.sau.com.au/forums/topic/115339-brushed-chrome-bezels/
  • Replies 125
easy as mate,The cluster comes out, then the clear plastic just unclips from the housing of the face plate, then just install the bezel set over the front of the dials. and clip the clear plastic back on, and your done :)
takes around 10 min tops, to change the whole look of the cluster :P
I got my self down for a set. WAY BETTER THAN PAINTING THE FACE PLATE!
kezza
hey, excuse the ignorance, but how do you get behind the plastic to change them? do you just take the cluster out and remove the backing?
ya its easy...I have doneit a few times wont take u more than 5min once the cluster is out.
KJ. btw thats a great price for this product...I paid double for the same FTO one.
yeah, Cyberstork has very good prices and terrific quality!, Thanks for the plug Khunjeng!
Ok,
DAN is in.
KAS is in.
Send me a pm dezz and you can be on the list mate :)
KJ is in also!!! $140 to the door!! nice1...I should have got the dials after all and not got them seperately!! next time :D
I'm sendint Kez a PM of confirmation in 5min once I have sent the funds (although they might not clear until monday)
KJ
The next thing u need is the needle caps...have a look at my FTO cluster below!! sorry about it being bright...
Edited by khunjeng
Which business is supplying this group buy Kezza
btw I have an R33 S1...I guess this is important!!! heheh KJ
No worries KJ R33 GTS-t S1 :worship:
Kezza mate, 2 thigns:
1. can you get the needle cap thingies? thye look really nice.
2. can you check to see whether the metal plate thingy is avaialble for sII r33? because the sII cluster is different and a sI one would look at bit weird.
Cheers mate
edit, saw theres no 33 pic available.
im interested in one for a s13 and a r33 series 1
thanks
james
wat about gtr?
Cheers mate
james: send me a PM of the bezels you need for year mod, and stuff, and ill give you my bank details and you can be on the list :P
KamikazeR33 Yes, what about GTR? Yes they are made for the GTRs as well bro! ie, pic up top of the R32 GTR.
I just dont have pics of all the bezels for all the cars. but they ARE made for them.
'97r33gtst-typeM' mate, i will double check your questions bro.. Im 99% sure they are made for the S2 R33...... The cap things are a good question, i will find out :)
kezza
interested if u can post a pic of an r33?
Hey Bill,
there is no pic available for the R33 right now, but its the same look as the other 3 pics available.
very very good looking, so I dont think you have to worry, :pwned:
is there something specific your checking for? I can double check for you if you need.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
