I'm looking for a front mount intercooler kit for a R32 that uses the side mount pipes.
As i can't find any kits available new or second hand i'm looking at alternative options.
(If anyone has one for sale or knows of one for sale please PM me)
I found this XR6 cooler upgrade, i could probably fit something like this in and just get some pipes
made up to suit.
Opinions on XR6 cooler?
This is the type if after but can't find:-
Edited by lows_13
https://www.sau.com.au/forums/topic/115505-front-mount-for-r32/
there was a thread recently about modifying an R34 gtt side mount cooler to fit R32 gtst stock cooler spot.
that might be an option for you.
Sydney kid posted a few points in there.. says it flows and cools well for 220 rwkw on his RB20det powered R32... and that is a track car. which is used only for thrashing constantly at the track.
might be comething to consider since they cost about $150 and an aluminium welding place could modify the end tank to be same as R32 stock cooler (SK said he paid $50) and you could bolt it straight in it's place.
so..
I have this idea about a "return inercooler".
I still have this idea about a "return intercooler".
rather than getting a 600 X 300 intercooler, getting 2 600 X 150 intercoolers and mounting them one on top of the other.
then you loop sone side back to itself.
You now have a 600 X 300 intercooler with inlet / outlet on the same side.
This is only an idea, so some comments, criticisms, etc would be greatly appreciated. I'd like to do it, if only to be different.
I figure it will save a little piping, too.
a mate of mine (member on this forums) got defected for "unengineered modification to chassis" for cutting the hole under the washer botle in the side sil.. $600 for engineering later...
those ARC 180 degree bend ones arent THAT bad..
air is now going through 2 intercoolers.. it would be too much of a restriction..
basically like air being pushed through 1200 x 150mm core.
Just one of the reasons why i don't want to go down that path.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
