Hi all,
I'm only just starting to get the bits n pieces required to start doing the track days with SAU-vic and was after a little advise in regards to the anchor points of the 4 point harness..
I have a R33 gts-t
the 4 point harness is an Italian made "motor quality" item
my questions:
1: for the inside (centre conside) anchor point, is it better to put it straight into the point where the factory seat buckle is mounted (which is part of the seat frame)? or maybe re tap the thread to suit the eyelet where the rear seat mount is bolted into the tunnel (frame of the car)?
2: where can I mount the shoulder straps in the rear without too much modification/fabrication? I've seen people mount them at the lower seatbelt points of the rear seat, but I'd prefer to keep a better angle and mount them on the parcel shelf. Can I anchor both shoulder belts off one eyelet (like the attatched pic, best i could do with paint) anchored in the baby restraint hole (will have to re-tap to suit larger eyelet bolt)? that would be the easiest solution for me....
all advise in regards to this welcome, as i realise there's probably around 1001 ways to do this. I also know its best to get a bar fabricatied through a race shop...but dont wish to spend $700 for 2 mount points....if i was going to spend that much i'd be looking at a bolt in cage then mount them off that...
3: I have an approved fire extinguisher with a stainless high impact mounting bracket...wheres it best to mount this? is there any regulations in regards to where it has to be through cams? I was thinking to avoid drilling holes in my car, i'd mount it at the base of the passanger seat, mounting a bar between both front seat rail mount and bolting it to that?
that'll do for now....so many questions hehe.....
i'd love to see ay pics of peoples 33 set ups to get a better idea if anyone has any?
thanks heaps for any help!!
Berin
https://www.sau.com.au/forums/topic/115553-can-i-mount-the-harness-like-this/
For the inside point, isnt the seat mounting a stud welded to the chasis with a bolt after the seat? If so, get one of the eyelets supplied with the harness, cut the thread off and tap a thread into the eyelet. You can then use the eyelet as the nut and clip the harness to it. Hope that made sense.
2, For the shoulder straps, the seatbelt (low) mountings are convenient but not right ( a lot of ppl still use them.) I had a cage so it was easy but I assume the baby seat mount is a better solution....what is the mount attached to?
3, passenger seat braket is a great solution, or bolt it to the rear or front passenger floor. It just has to be within easy rach of the driver while in the seat and harness. You won't notice extinguisher bolts thru carpet it is invisible
the baby restraint on the parcel shelf is just a tapped thread into the parcel shelf, but i was thinking of re-tapping it to the 12mm fine thread of the eyelet bolt and maybe puttung a base plate under the shelf where it screws in for a bit of extra strength?
but still not sure if it's ok to anchor 2 belts off the one eyelet?
I dont like the idea of using the child restraint.
Perhaps if you drill a hole at the front top edge and reinforce the back if it. Its just that i woukdnt want to be relyin gon the flimsy parcel shelf steel that is thing gauge and fiull of holes to save me in a accident. what does a baby weigh? probably fine for a 15kg bubs, but not a 90kg adult that just hit the tyres at Dandenong Corner at Sandown:(
What Inasnt said about the left drivers side lower mount....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
