I should be going to this one after I missed the barrington hillclimb. Anyone else coming? I'm sure i've been the only Skyline there this year, be nice to see some more.
http://www.lcct.org.au/
Well if you lend me your crank so i can finish my motor then i'll be there as well :thumbsup:
Limiter and 5th gear :)
You beat me to it! I'll post anyway!
Light Car Club of Tasmania
Multi-club speed event
Symmons Plains
Sunday 28th May
Details here
http://www.lcct.org.au/Club%20Events/Speed...0May%202006.pdf
Entry form here
No and no!
I am still rebuilding the RB20, but i'm also about to start doing a RB30DET as i have just bought a head. will be a weapon in the light VH shell!
Not sure what i'll fit, obviously i'd love a RB30DET but I love the way the 20's rev!! Good for holding big drifts but then again i'd like more torque...
I will still be out there helping out, hope it doesn't rain!
  • 3 weeks later...
Well I had a good day, I got a best time of 1:06.00, but I ran out of brakes at the end of the day (again). I was more then happy with my time though, since i took 2.5 secs of my previous best.
There was another GT-R out there that got a time of 1:05.3, but he had AP Racing 6 potters, and more power.
Hopefully I can stop my brakes from running away before next time.
What pads do you run? I recently bought some Hawk HT-10's and were happy with them for a few laps before I blew mine up last time! Lookong at $300 though.... or try DS3000 Ferodo.
Standard calipers and particularly rotors, either Sumatomo or Brembo are just too small for the weight of a GTR in competition. I totally warped a set of brand new DBA 5000's (alloy hats) after just two stages of Rallye Burnie last year in my car, and that was with 3" ducting running right into the veins and nice and progressive Pagid Blue pads.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
