Date:14 June 2006
Arrival: 730am registration
Break: 12:30pm
Finish: 4:30pm depart
DNA RACING WORKS invites ozhonda.com , pulsar.org.au, skylineaustralia, clubrsx to attend a track day. the day is just to get out and socialise and have a good time
Note: Each participant will be required to produce their drivers licence for legal purposes and sign a course indemnity.
Places Availible: 37
Cost $165
Spectators Free
With the positive response of the last track day i figured its time to have one at a different track.
The day will be organised by Ian Luff and all drivers will have a ride along with a pro to get one on one tuition.
Monies need to be recieved by 14 May 2006
contact jimmeh on 0405 072 590 or [email protected] or PM me
Programme Format:
The group will be broken into three teams - each with their own ILMVA personal trainer who will coach
and motivate them to move outside of their comfort zone and achieve success, both individually and as
part of a team.
Over the course of the day, there will be three (3) workstations that each group will contest (each runs
for approx 45minutes with a 10 minute changeover). At the conclusion of all three activities, the track
will be opened up for a ‘speedfix’.
The track will close at 4:00pm and guests will assemble in the VB Room for a Trophy Presentation, for
the following awards, Top Gun, Hard Charger, Hot Shot and Skilled Driver.
Drive Activities
Super Slalom - A driving discipline where eye-hand co-ordination and throttle balance is needed. Marked
with soft plastic traffic cones, the objective is to negotiate the course in the best possible time without
hitting the cones.
Cloverleaf - This high adrenalin driving test will really sharpen a driver’s reflexes. Rapid steering input is
needed to make it to the finish line with smoothness being the key to success. A great sense of direction
is needed to gain maximum points.
Hill Climb - The name says it all, but we provide an extra challenge. Again, the course is marked with
plastic cones with one part of the course wet down to create a driver skid control test. Lots of fun
guaranteed and plenty of sideways action.
Open Track - After lunch is when u get to put you newly learn skills into practice.
keep it tuned
Edited by mrjdm
https://www.sau.com.au/forums/topic/115762-track-day-at-oran-park-14-june-2006/
I think you may have missed what i was trying to say, i mean, enter one car with two drivers and split the events between the two drivers. As i would only enter for the last part, so the rest of the day would be a waste
illl drive your gtr in the morning session :D:thumbsup:
the whole day will take place a oran park
sorry i think you misunderstand. there are 3 comonly used circuits at Oran Park. Oran Park south, Oran Park Nth (go cart track) and Oran Park Gran Prix.
edit: primordial beat me to it.
