  • 3 weeks later...
I've always thought the following:
The green or blue metalic shit they have on M3's.
The poo pot clay colour they have on BMW 4wds.
Mazda 3 blue
Ford Falcon blue
Honda Jazz baby blue (James has it look the cool)
... hmm thats about it.. the m3 blue is my favourite.
  • 2 months later...
