when is this cruise and where?
answer:
MEMBERS only cruise. Is for MEMBERS ONLY
When you become a member then you will learn little padwaan. :O
Non Members: Its the 'Choose Your Own Adventure Cruise" .... have fun :)
Being part of a club makes you more aware of others on the road and more respect for each other.. now if some random joined in on the cruise and was being a complete TWAT on the road, the club takes the blame..
You talkin me.....
If it takes being part of club to make you more aware of others on the road, THEN MATE MAY ALL MOTORISTS from gaywoos to land cruisers beware when you special awareness powers wear off when you forgot to renew your club membership aye bro.
I Don't speak pom but you sound like abit of a spotted dick. I went on the last cruise that started at city west and 3 other F*&KERS almost made me crash and one WAS a member. One guy spun out "360" in the middle of a intersection!!!
Anyways just don't like people saying I can't drive on the road at a specfic time at specfic place because I didn't buy sticker yet I donated to SAU.
Mate alls I know is no "civilian" has the power to say where and when I can and can't drive my GTR unless its in violation of some specfic Traffic code or an order from the WA Police Service.
Simple.
You talkin me.....
Simple.
dude no one was having a go at you, ease up a bit. your right, we cant stop you from driving, but if you want to come why not just join the club ? if you donated then why do you have a problem paying to be a member, its not exactly a lot of money and you do get discounts at a few places too. theres no need to get agro cos now people will think your an idiot, and im sure your probably not.
Dude better get that medication re-scripted eh?
Going ape-sh1t on two forums (that I can count so far) at the same time for absolutely NO REASON whatsoever. Maybe don't bother joining our "civilain" club eh...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
