Sounds like we should do something this weekend then i guess.. :mad:
Paul - I'm going to be at SST round 9am for a little while to get my knobs fiddled with.. Will be keen for a drive after that if you wana come down and catch up..
  • 1 month later...
What about the idea of visiting members areas. Each weekend one area. Sounds good? Ha? Find a carpark or the cafe strip. Fremantle has the car museum and a cafe. Heaps of parking and Maritime musem next door provides great photo opportunities. Great backdrop at night.
So how about the E shed car park Saturday night???
If you're looking for cruise routes, I did one for my birthday in August .. The jist of it is:
Starts at City West, down to coast, all the way up coast to Mindarie, cuts through pines to wanneroo raceway, goes all the way to the end of neaves road, and over great northern, up into chittering valley, back down to great northen, through swan valley and ends at bayswater.
It's like a 200k to 300k cruise, and with 3 or 4 ten minute breaks, it lasts about 3 hours.
If you're interested, I'll dig up a map and post it.
Jason.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
