With an safc II or a NEO AFC 210-220 will be a reasonable target
Stan had 211rwkw with just an safc 2 on 11 psi of boost (this is correct stan???) Keep in mind it is an r34GTT Auto
Are you after pictures of the inside of the rear housing ? ie. of the turbine ?
yeah,,
eg...
  • Replies 264
Posted Images
hi guys,
ive been asked this a few times differences between safc and powerfc. they will both make very close to the same amount of power if both have been tuned correctly. but clearly the powerfc winds hands down if it has been tuned correctly and has a bulk of its load points tuned. if you have the IGN and INJ tuned in the low load / light load areas the car will feel much better to drive, response will be better and fuel economy better than safc + stock ecu.
the main difference is the powerfc will support more mods and if tuned correctly will feel like a new car to drive.
both are only as good as the tuner.
car 1 - rb25det with safc
car 2 - rb25det with powerfc
its not like car 2 is going to make twice the power as the ecu costs twice as much. it all comes down to tuning and how the car drives, average power is the key here. the engine should feel nice on throttle response (IGN timing), come on boost nice (IGN timing) and cuirse will with good economy (INJ tuning). i would expect the power difference to be 5 to 10rwkw at the most
also powerfc has the following advantages over safc
adjustable IDLE
configurable knock warning
configurable injector warning
configurable airflow meter warning
airflow meter change support
injector change support
complete ignition map control
complete fuel injection map control
no speed cut
no excess airflow cut
I would add that there comes a time when tuning with an SAFC where you want to lean it out a bit more. But you can't because that advances the ignition timing and it knocks. So you end up with richer than desirable A/F ratios and hence sacrifice power. Power that you could unleash with a Power FC by virtue of its independant control (mapping) of fuel and ignition.
:mellow: cheers :mellow:
Hmm damn i guess i gotta just drive the car more often. It take me about 3 weeks to reach 1,000 kms.
Weekend car only you see.
Hey Dan, just wondering if you got the exact turbo as Satanic has?
His one is customized for auto transmission. Exactly the same as mine because i also have auto tranny.
Do you have auto or manual Dan?
Yeah my car is an auto as well, same dealeo that Stan has.
I agree with Paul and SK, the SAFCs become a little bit redundant at higher levels of tuning as the ignition cannot be touched... those with the SITC, don't worry about my comment, you're very lucky to have that option :mellow:
As for my setup, the very last tune was done using all the basic modifications barr a full exhaust (cat back only). We hit 200rwkw at 10.5PSI, boost dropped off a bit at peak power due to something.
Did another power run with a full exhaust (split front/dump in 3", 3" hi-flow cat, centre resonator removed from cat-back), splitfire coilpacks, re-gapped plugs. No tuning was involved, just a straight power run and we got 217rwkw. Again there was the issue of the boost dropping off. Surprisingly (think someone knocked it), the run was done at 10psi instead of 11 so that may or may not mean something.
I have since wound the boost right down to 9psi as it is currently running VERY rich. SAFC will be coming out in a week or so, engine work will commence and next tune on the 22nd will be using a F-CON V PRO.
With that, I will be able to max this turbo out without dramas and hopefully get to 260-270rwkw (18-22psi)... that's if the gearbox doesn't blow up first :mellow:
Thanks
Stan
Dam you all. You all sound like old BiTChen grandmother. Just relax.
I belive that when you compare price versus gain, these turbos are great. I am going to be sorcing one soon myself, but from what i can see, if you have the bugdet go get HKS ect, and half of the cost is the name.
Anyway Slide. Did you get my PM i sent you. It was in regards to getting one of these for an R33 to get 250rwKw.
Saving money for some 550cc from Sard I think or if I'm gonna go absolutely stupid with the next turbo etc, I'll go for the 710cc I think.
Bass Junky in another thread said that the new injectors for the 350z are a direct drop in? Hope he's right.
So any one who believes that $1750 for a ball bearing high flow is better value for money is bitchin? :mellow:
Let me give you another example of why I never use plain bearing turbos, EVER.
Just before Xmas I was doing a suspension set up clinic for an aftermarket suspension manufacturer. There were quite a few guys there with turbo cars, an S14 being one of them. It had an off the shelf fairly new Garrett plain bearing GT25 for around 400 bhp (240 rwkw). About an hour into the day the alternator wiring died from the heat and shorted out. This killed the electrics and the engine simply stopped, instantly.
We towed it in, let it cool down till after lunch and I bodgied up the wiring so he could finish the day. Started it up and it wouldn’t make any boost, dead turbo due to the plain bearings seizing up from the heat soak and cooked oil trapped in the core. So the guy wasted $450 for his day and it cost him $600 to fix the turbo.
That makes his decision to buy a plain bearing turbo not so economical.
As I said in a previous post, it's your money, spend it how you like.
Edited by Sydneykid
I have only seen a flow test on one set of standard 350Z injectors (300 cc's) and they flowed less than R34GTT injectors (370 cc's). They were more expensive as well.
Part numbers as follows;
JECS # 166005L700
Bosch # 166002Y915
Edited by Sydneykid
That was my point. If you have the money, go for it. But for those who don't race, and simply want something that will put a grin on their face, evertime they step on the loud pedal, then this is a very good option.
Thats all. No offence to anyone.
I was referring to the aftermarket injectors for the 350z, sorry for not being more specific.
If you punch in the R34GTT into Nengun as your car, it will come up with a whole set of injectors that are larger than the Nismo 480cc. There is no mention of aftermarket fuel rails/collars being required so I believe they are "drop-in"
I'm just relying on information I've read, so there is every chance that I'm mistaken.
S
Yeah 350Z and R34 use the same injector size, thinking of maybe contacting APS as they have 500cc jobbies for the 350Z, but I'd be happy with anything ~440cc at the moment. The R34 is almost finished as far asI'm going with it, the 350Z/V35 TT is on the cards for next year.
If what Dan (and I) is saying is true then the potential is limitless :) Especially good since all the tuning shops are now focussing on 350z/v35 over in Japan.
New GTR is the next frontier... company lease car here I come :nyaanyaa:
dont know if i'd go that far little buddy. :nyaanyaa: unless we are talking about different japans'? last time i was there sure V35 and Z33 were growing in popularity, but they are still no where near being focussed on by all tuning shops. many places are still building lots of 34, 33, 32 demo cars and of course plenty of toyotas too.
We have received our shipment of cartridges for the T3 Highflows so for all the people that wanted them late last week they are ready to be made again.
Only brand new Garrett cores will be used now for all Highflows.
We hould also have results on a 300zx set of highflows very soon.
We use GTIR Compressor covers. fit larger compressor wheels and slightly larger but better flowing turbines aswell. :P
:) Aaron
Ummm no...
I have had quite a few worthwhile discussions with both Gary and Paul, who are both knowledgeable.
I am referring to the sheep...so re-read my post and build a bridge...
Don't turn a good thread into your own self promotion... :thumbsup:
Sorry to bring this up, but in the interests of my own self promotion I can't hold back.
Your quote was:
'P.S. No one should discount this product until proven otherwise, the KKR turbo's were mocked repeatedly, now they have partly proven themselves, some keyboard mechanics should shut the f**k up'
And this was in a location where preceeding it there were 3-4 pages of posts where there wereno bad comments written about these turbos, infact the only comments written which were not relating to the product being good were posts from paulr33 and SK discussing the merits of examining all your options (BB turbos etc) before making your choice.
So you could see how I misunderstood you as meaning they were the 'keyboard' mechanics discounting the product as, as far as I could see there was no other comments relating negatively to the product in anyway.
I apologise to everyone in this post for bringing this up here in this thread as it is off topic, I just wanted the chance to explain myself.
I'm sorry for any misunderstanding this may have caused between us Bobjones, my previous post obviously came out the wrong way, I wasn't trying to discount anything you had said at all, I was mearly trying to point out that there were healthy arguments on both sides about the issue of types of bearings used in turbos (Which from my own fault, as I posted above, misunderstood you to be refering to posts made by paul and gary)
Consider the bridge built and used. :banana:
How can you ensure that shite-loads of oil is able to go thru this turbo (so it doesnt fail), ie what exactly needs to be done? Worried about that factor!
Also, how long should the car idle prior to turn-off after a normal street drive?
cheers.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
