The video settings are critical for decent non-choppy game play.
The new crapola 1.3patch is really nasty, world wide constant server crashes and 'connection problems'. Not to mention the bad arsed incorrectly displayed opponent, some times it shows them as red when its actually your own team member. :S
Another bug the 1.3 patch has introduced is if you bail out of a helli 'just' before its blown up it states you killed the other team members in the helli that died.. lmao.. :P
But apart from that I swear the new patch has reduced the map loading times.
  • Replies 146
Posted Images
So is it today, same server as before?
i want to gun some shit down with the minigun in the blackhawk :)
I have organised for the same server as before for 9pm.
Let me know what maps, and the number of players etc.
I think we are better off, running 16 players until that's filled, then upping the size as more people join.
Addmittidly, that means that there will be numerous server restarts, however, I think that this is the better method of keeping the games busy.
Please advise what maps you would like, and if you would like bot's. (16 players maps only with bots, No Wake Island)
Finally, the password for tonight is skyau
Let me know if you have any issues.
Anthos
Anthos
So as far as i know its as follows:
Clan Server BF2 IP: 202.60.83.12
Port: 16567
Password: skyau
Time: 9PM
Maps requested please :P
Karkand
Mashtuur City
Songhur Stalemate
Zatar wetlands
BTW my username = Johnny.Funpants
My brother Mach32 is playing and my other brother and his friend (4 total) we will be....
TEAM JERK :D
See you all in 2 hours
Rosco
Server is up and running as requested.
Details below are correct.
Please advise if you have any questions / comments / slander etc...
Karkand
Mashtuur City
Songhur Stalemate
Zatar wetlands
Maps where added to include those above...
All other details where correct at time of posting this message.
hey if anyone want to get on ill be there wasting time waiting for 9pm... :P
actually, what would be interesting is if the special weapons are enables. i think it could be done on the older version, dunno bout the new patches n stuff...
Edited by Freddy Kruger
no me and cubes just left
geez - totally forgot. Plus the motogp was on foxtel, an awesome race between Caprirossi and Rossi.
Havent played BF2 properly for like 10 days now LOL
Mind you I went from 15000 to 26000points in a couple of weeks, so I need a bit of a break from it! :(
Yeah, tried last friday/saturday but the new 1.3patch is awful - cant stay on, always booted off with bad connection now. Tried again this weekend (fri/sat) but same problem.
Thanks BF2 patch 1.3 - now I cant play the damned game.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
