Stupid question (and sorry to hijack :D) but where does one get wrap and flameproof paint from to paint over it (ala Beer Baron styles). Just got my dump pipe made and want to try and contain the heat somewhat.
Is it something that mopst places sell like Autobarn?
i got the wrap from Flyn (was cheap enough) and the paint from autobarn. i used the black paint. comes in a red can and says flameproof on it - up to 1500 degrees f. give it a few coats.
You can also buy it through Racespec on SAU. His prices are much better than R.R., but for the paint it probably doesn't matter much.
You can also get it from E.T. Performance in Dandy. They sell a couple of different widths and lengths, and pretty cheap too.
Also, be interesting to see how you go with that black paint...personally i will never use that rubbishg again. First can stopped workign after about 5 seconds leaving me with a uselass $50 can full of hi-temp silicon spray for exhaust wrap that i couldnt get out of the can
i believe i have some useful advice. with that can what sort of nib does it have? you should be able to replace it (im not sure what sort of can it is) so find a nib that is a similar size. put it on the can, turn it upside down and spray away. this will clean the tube that goes to the bottom of the can and spray just gas through it. (does that make sense?) every time it block up just turn it upside down and pump the nib (it should clean it if its still wet).
even a lynx can nib should do te trick. (if it fits)
forgive me if im wrong cos i assume its a can with a nib.
cheers. james.
Its not worth bothering with the flame proof paint. The moment you get your exhaust really up to temperature when on boost it will fry off instantly.
I actually had problems with my other car and melting the white header wrap. It first started to go brittle, and then started falling apart. Closer inpsection revealed that the glass wrap had melted and I had glass beads in the pattern of the header wrap stuck to my stainless manifold.
I've since changed to graphite impregnated wrap from horsepowerinabox and that sorted out the melting issue. Here's a pic of my setup.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
