Just went down now and the line is still like a km long and it's 10:30pm at night :) We got told only the store closes at 11, drive through will still stay open. The police were still there too and saw a bunch of guys in a commodore in the kmart carpark getting a talking to by the boys in blue ;)
  • Replies 191
Posted Images
how do they compare?
Do they taste better than the sydney version??????
ill probly cruise down there next week with my mates(r34,s15,05rex).
Should make it a "Krispy KRUISE night "????
whos up for it?
ill let you know when im goin.
cheers
steve
Edited by Tough R34
AHAHAHA i got like to the turn off and even that was bloody packed so i just kept going and took the next exit and turned around and went home :D
i reckon it will be packed for at least a week.
Take that back Koala!!!
I finally got some... queued up in the car at around 10am and got them in my greedy little hands at around 15 to 11... so much quicker then the line outside.
omg im in heaven
