i have install tomei poncam 260 in 9.15 & 260 ex 9.15 after i install my car startes to hunt at 1100 rpm to 915 rpm is this normal or i have a problen , what should i do with the power fc to solved this problem if any
https://www.sau.com.au/forums/topic/116321-tomei-poncan/
The tuning for idle could possibly be well off (leaning out making the car sound lumpy) and from memory when we had my poncams dialled in at 0/0 the car had a bit of a lump anyway (appeared to be hunting around a few hundred rpm).
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2139079
i notice that because it so lumpy i cant get to timed the engine at 20 dec timming from the cas, at the moment i have them dial in at 2adv in and 4 ret ex is this the best setting for these cams , also do i have to add more fuel in the vacuume scale say 300mmhg to 275 mmhg this is where the car would idle
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2140791
With regards to cam gear settings, we found some really wierd settings worked best with my GTR... there was a massive amount of retard on one of them, something like -7 degrees. Get your tuner to play around with them and find where they sit the best.
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2141485
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
