i have install tomei poncam 260 in 9.15 & 260 ex 9.15 after i install my car startes to hunt at 1100 rpm to 915 rpm is this normal or i have a problen , what should i do with the power fc to solved this problem if any
https://www.sau.com.au/forums/topic/116321-tomei-poncan/
The tuning for idle could possibly be well off (leaning out making the car sound lumpy) and from memory when we had my poncams dialled in at 0/0 the car had a bit of a lump anyway (appeared to be hunting around a few hundred rpm).
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2139079
i notice that because it so lumpy i cant get to timed the engine at 20 dec timming from the cas, at the moment i have them dial in at 2adv in and 4 ret ex is this the best setting for these cams , also do i have to add more fuel in the vacuume scale say 300mmhg to 275 mmhg this is where the car would idle
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2140791
With regards to cam gear settings, we found some really wierd settings worked best with my GTR... there was a massive amount of retard on one of them, something like -7 degrees. Get your tuner to play around with them and find where they sit the best.
https://www.sau.com.au/forums/topic/116321-tomei-poncan/#findComment-2141485
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
