  • Replies 101
Posted Images
Well seems we have had a major setback. Liz has not made it. Maximum entries being 60 with 5 reserves. You must be very pissed off at the moment Liz. This grumpy old bastard will be counting the entrys and If the roster isn't full I WILL BE HAVING WORDS.
I still have to go on sunday so what about 1.00pm at that car park?. Jas post me your mobile and I'll ring you when we get close.
Neil.
Even more pissed now that I've cancelled the arrangements I had to get my car fixed before next weekend because of their decision... then this morning, I get an email from the event secretary saying he's changed his mind due to lack of entries.... GRRRR
Damn WSCC saying I wasn't a champion, I mean, sif I'm not a champion!!!! I think they actually found out I was a champion hence the sucking up now! hahaah
I'll still be heading down to watch as I'm keen to get into these hillclimb thingys!
so they said you not in, you cancelled car repair, then they rang to say you are in? good job. oh well, there is always the next one! plus are you coming to oran park on 29th?
yeah a bit frustrating!
nope ;) not fair on the boss to ask for time off work right now... I'm settling for the Luff day on the Sat after it's not full circuit but it's better than nothing!!!
I'm going to try and get to a McGill track day sometime soon, big mcgill fan i am!!!
oh man, I just saw a video of the hillclimb... stuff it.. I'm keeping my entry and if I manage the get the car working during the week, I'll be there with bells on!!!!
The silver car going up one?
Did i email that to you?
You all so want a Peugeot after seeing that 60 year old Panel Van.
Jas I did try ringing you but I must have typed your number wrong cause I got someone else.
Liz the great, thats the spirit girl.
I'll have to check the vid when I get home,,,crapbox thing here is as good as the cars we sell,,,bloody euro-trash.
Neil.
Neil.
Neil i pmed it too you!
and :no: to those peugeots haha i could not stop laughing..
Neil - Corinne has a video with you in it
Im so buying a Pug tomorrow, i just found some change on the floor so maybe ill buy 2?
yea it was sent.. :)
Which vid is that? Got a link or something?
I posted a link to the NSCC's gallery here earlier. A pewter S15 with a roof-mount camera doing the run as well. Wouldn't mind seeing some other cars doing it.
I have a vid of a NA S13 doing it in the wet floating around somewhere as well.....
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
