  • Replies 101
Posted Images
no hillclimb for meeeeeeeeeeeeeeeeeeeeeee.. so pissed offffffffffff but whatchagonnadoooooooooooooooo?
there is another club event coming up that I'll look at entering
but for sunday, I'll just head down and watch neil.
see you then.
Anyway, I should be coming to spectate on Sunday.
I'll bring my Manfrotto 241v camera mount, if someone wants to bring a video camera, so you can do in-car shots.
Mate im doing a trackday on Monday - would you mind if i borrowed it by any chance just for the day?
nope! email [email protected]
Sent
Sigh,,,My budget doesn't extend to such luxury's as a video camera.
Neil.
Whats the actual story behind the ambulances?????
Those open wheelers are quick!!!
Heres a short vid of a GTR launch at Huntly (5500rpm)
http://s65.photobucket.com/albums/h228/D_I...nt=P1010076.flv
Yep 30.93 was my best time, but I did improve with every run. It's called lack of traction. Took me 5 runs to dial in the back end and then on the 6th run I think I've broken an axle on the start line. It went BANG. Lost the front splitteras well so back to being a busy boy for the next week and a half. Bloody Grafton is close.
I gotta say though I had a great time and will do it again. The GTR's 1st launch was awesome,,, big 4wd lightup and then it squatted down and took off. The pushrods next to me went off. They had never seen anything like it before.
The ambo's had to treat a old fat driver(I mean FAT) at the top who had a heart attack. He's okay now though.
Neil.
30.93?
I thought you would do way faster than that - ive done a 30.1 with 2 stuffed gear changes and a slide out of turn 1. I had 2 better runs but they werent timed (phone with timer stuffed up)
Sad news about the guy with the heart problem
AND the axle :D
Bring on Grafton !!!
Yea Steve 30.93 is way SLOW. I just couldn't get temps up on the dunlops. The 1st 4 runs I had wheelspin in 2nd going up the short straight and heaps more from 3rd up the longer straight. There was no way I was gonna push through the fork with no traction. The 5th run was better and I was all primed on the 6th to take the fork flat out but bang the axle went. Next time I know what to do.
Neil.
Neil,
Ill try burn the limited footage i got to dvd for you.
Jase
That would be great Jase,,,footage would help me get some sponsors on board. She's bloody quick,,,we just need to talk to one another a bit more. She wants to do her thing and all I want is for her to stop showing off.
I'll give her one thing though,,,It's a crack up when she farts about 30 secs after turning her off. BOOM,,,everybody shit themselves.
Neil.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
