Umm... its wont happen.
They have a rouge moderator problem obviously.
This mod group isnt just "appointed".
We are all quite sane and normal people :(
We dont "bitch" about anyone behind thier back in some secret section etc like what seems to happen on ozhonda with comments like "LOL you owned him"
Thats just silly behaviour.
I think its safe to say that SAU is rouge-moderator free
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2140953
having said that no site is safe, if a good hacker wants to get access they will, but don't see why a good hacker would waste a 0day exploit in SAU or ozhonda :O
Its also possible that someone knows someone who works at the host, or someone has an account on the same box and the permissions aren't setup correct for the site....
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2141523
yeh I remember that...
it was only the banner though
let's just say that the person who did it was just a bit young and silly... there was no serious intent to hack the site the way that this honda guy has.
he knew he did wrong :O
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2153019
someone else remembers it, cool! i havent been drinking too much!!!
it looks like this is the real thread to discuss the ozhonda hijack, rather than that wasteland one that got taken over by the usual suspects.
i'm amazed at some of the raw agression that's been posted on ozhondasucks. I cant see that happening to SAU at all.
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2155415
no one else seems to remember........
maybe we've both been drinking too much >_<
ps where's the alcoholic smilie when you need it! grrr
BRING IT BACK!!!
yeh I remember when it happened.. it was a yellow car with some one guys handle tagged on it.. was only last year some time
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2159021
  • 1 month later...
didnt this site get hacked once ages ago??
i seem to remember something about a WRX banner being put up??
am i right or have i been drinking too much :S
http://www.skylinesaustralia.com/forums/in...topic=75938&hl=
hahahahhaa
It was a yellow 04 mitsubishi vrx
the pic i posted in here doesnt work anymore but ill try and fimd it.
He is a little stooge and you would be surprised how much information we foumd on him that day whether he did it or not
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2265549
heh, yep we've had some hacks and hack sttempts in the past.. We have daily backups now so even if they succeed, we'll just revert to a backup.. no biggie really. We are pretty secure tho, so no real need to worry.
https://www.sau.com.au/forums/topic/116411-ozhondasuxcom/#findComment-2266645
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
