Just looking at some of the data and mainly one of my better runs and I started comparing it against some of the timeslips found in the Drag area under Motorsport. I found one that was similar to one of my runs but the MPH are very different.
*from the drag thread under motorsport*
R33gtst
ET: 13.79
MPH: 91.6
60': 1.99
Ultimate fuel
Firestone firehawks 225's
paulr33
ET: 13.75
MPH: 105.51
60': 2.13
Optimax Fuel
Hankook Sport K104's 255
The MPH for each runs are very different. That says to me he had lots of traction and I didn't but the net result was we both ran very close times but my MPH was much higher. One interesting thing I saw for R33gtst's run was track temp, listed as 32deg and ambient temp 25. The ambient temp for our day was around 18deg and for my 13.7 run above the ambient temp was 16. See the compare sheets below.
Not trying to be a know it all just trying to learn and improve
  • Replies 211
Posted Images
i had a video camera going all day, courtesy of my gf whol filmed for me....ill see what i can do about getting it on to a dvd or something, and then ill try upload some of it....might take a while as ive never had any experience with editing video etc on a pc
got some good footage of pete's burnouts up close, abcent too....in car runs with justin911 at the end of the day....hehe
here's the photos taken on my camera...nothin special obviously, but my little brother was taking some photos for me :D
http://s58.photobucket.com/albums/g258/saudez/
Hey Dezz, i was gonna come say hi but all i could see was your gf sitting in your car looking bored :( and i couldn't find you cos i don't know what you look like :)
sorry to hear that it all ended prematurely for you :D
Absolutely spewing that i didn't have my 32 ready, can't wait till the next one!
Hey Dezz, i was gonna come say hi but all i could see was your gf sitting in your car looking bored :( and i couldn't find you cos i don't know what you look like :D
hey mate, didnt even know you were there...
i was the guy crying....hehe
mrs looking bored....she wasn't so much bored as she was freezing, sick, and tired....but she enjoyed it...she got some decent footage for me too :)
i farked my gearbox, and i cant wait for the next 1! like i said, 1 a year isnt enough!
