As stated I'm looking for some one to tell me what this turbo is. Unfortunately I can't give you a photo.
It's an APEXI AX53B70! I found it on a variable valve RB25 at the local wrecker who have no idea of it's value and was thinking of getting it
Does anyone know? I suspect the ID numbers represent the A/R's, so a 53/70 turbo
It has an adjustable wastegate actuator rod and the standard dump with internal wastegate, Braided oil and coolant hoses.
https://www.sau.com.au/forums/topic/116683-turbo-identification/
I suspect p25 as thats the only listing for rb20/25's. They are roughly equivalent to 2530s so should be a good little unit on an rb20.
If its under 800 and you are willing to take a bit of a punt on it's condition (as with all second hand wrecker turbos) then grab it.
  • 2 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
