In the boot Nizmokid, just behind the partition between the boot and battery compartment.
My cars at the panel beaters right now and I cant for the life of me remember exactly where its bolted onto. From memory, I think its on the back part of the panel that surrounds the suspension rig (shockers and springs).
https://www.sau.com.au/forums/topic/11683-rear-strut-brace/#findComment-202935
Strut braces obviously stiffen the car. This is a good thing if you have the suspension to match...if not then sometimes the flex can actually work to your advantage rather than to your detriment. Skylines are also quite stiff in stock form when compared with a commodore or a falcon for example, especially in the rear sections. I would suggest that your money may be better spent than a rear strut brace.....
If however you have too much money and are stuck with what to do with it....different story....rear strut brace does look good when the boot is open.
Cheers
Russ
https://www.sau.com.au/forums/topic/11683-rear-strut-brace/#findComment-203424
Hi Guys, front strut brace on a Skyline = definitely worth the money. Stiffens up the upper/inner mounting points for the front upper control arms, so actually does something.
Rear strut brace on a Skyline = not really worth the money. The upper/inner mounting points for the upper control arm, don't mount to the body, they mount to the sub frame. So achieves almost nothing.
Hope that adds to the knowledge base.
https://www.sau.com.au/forums/topic/11683-rear-strut-brace/#findComment-203517
There is two studs on the bask side of the suspension towers. It should slide straight on. GTRs and Type M's come with these standard don't they??? I picked up a Cusco OS type one second hand a little while ago. It does stiffen the body a bit. I noticed that when getting a bit of drift it seemed to be a little easier to hold, I think cos of the extra chassis stiffness?? And now when taking the angle over kerbs into driveways it will pickup the inside rear wheel. Besides it looks tuff when you open the boot!
https://www.sau.com.au/forums/topic/11683-rear-strut-brace/#findComment-203522
hey guys,
i have one in the boot of my R32. it site rite in the middle of the boot but make a diff on the handling. plus i have after market suspension which is fairly stiff and it sticks to the road like s**t to a blanket.. the only thing is my amps for the stereo are mounted on the back panel of the seat makes for a pain if you want to do some adjusting
https://www.sau.com.au/forums/topic/11683-rear-strut-brace/#findComment-203966
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
