Ive been asked a few times now about how hard it is to drop the subfram on skylines in order to install these Noltec subframe mounts.
Id like people here to add anything that may help others if they attempt to do this themselves (with help from mates etc...)
Firstly u need a pit or the car up on stands (the rear has to be jacked up on the chassis, not part of the subframe as you are removing it)
Then u need to disconnect the tailshaft. Undo the rear strut tops from the body. (On a GTR the lowers are a U bolt - so they would drop out when the subframe is lowered??) Then clamp the brake line, and hicas line and disconnect them. Now check out your cat back exhaust. If yous is a bolt on sytem, unbolt the rear muffler and your away. If yours is a welded system, just remove from the cat to the rear.
The rear should now be free from the driveline. The only thing left is the 4 bolts going through the actual subframe bushes holding the subframe to the car. Place a jack under either side of the subframe and remove the 4 bolts. I suggest u get hold of an air compressor, as these may be stiff bolts, or may require soaking in Rost off (a silicone creeping spray that works its way into the thread to loosen the bolts)
Once the bolts are out, then have someone on the other jack and together lower the subframe down. If you havent removed the wheels, just roll the whole frame back and away from the car :( Its out now have a break...
Now u need to get the bushes out using either of the 2 methods. First is to use an oxy torch to blow/burn out the bushes. This is extremely smelly, as u will have clouds of black smoke pouring out, so not recommended. Second method is to go down the hardware store and buy a hole saw slightly smaller than the bush. Use it to cut down the hole the bush is in and it should remove most of the bush. There is then a collar that is normally on the outer of the bush (i havent seen the std bushes, so this may or may not be in the subframe, have a look before u install the new ones) See 1st diagram for pics of replacement bush with collar.
If there is the collar in the frame, u need a hacksaw to remove it. Undo 1 end of the blade, push it through the hole, and redo the hacksaw up. Now cut the outer collar out, taking care not to cut the subframe going too far.
Now grease the bush a little, and sit them in where they go (the right way up too) Then using a mallet bang them in.
At this point you can install urethane pinapples to tune (angle) the subframe for traction as well. (see diagram)
All that is left now is to re-install the subframe the way you took it out. Once it has been installed, you may need to bleed the brakes, and the powersteering (hicas).
Please allow a weekend to do this, and have a mate on hand, and a ride organized to go to the hardware store (holesaw). Maybe to repco for brake/ps fluid also.
I find a BBQ and alcohol will have many hands on deck if needed.
Anyone that has done this, or can offer advice please do. Im sure it is the same for GTR and GTST (apart from lower shock mounts, and Attessa - someone help on this?)
later i'll add pics, and get this moved to the tutorial section as well.
Please add any comments or suggestions to help.
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/116840-removing-subframe/
A couple of minor things -
The brake lines dont need to be taken off. Unbolt them from the hub and leave them wired up to something, one of the little holes in the body work (there are a few under there)
Remove the struts comlpletely as it will just get in the way when you drop the subframe.
As for installing the new bushes with a hammer, i think you will have a few problems. I have recently installed new lower control arm bushes which also have an outer sleeve similar to the ones shown. (though half the size obviously). They are a very very tight fit. I am very doubtful you could get the bushes in without a BIG press and the right dies without damaging them. The lower control arm bushes took 2 guys, a big bench vice and a metre of pipe on the handle to get in. The subframe bushes have over double the surface area of the ones I installed.
Other than that, i think it will be a very worthwhile upgrade once complete.
these will almost certainly require an industrial press to be installed into the subframe. the tricky bit will be getting the subframe onto the press or vice versa. make no mistake it will be a bastard of a job, but by all acounts it will be worthwhile.
http://forums.nicoclub.com/zerothread/97924
Guys heres a s13 subframe with pics on how to do the installation
Would anyone know if the freezer trick would work with the noltec ones? :laugh:
I think the bolt with 2 washers and pressing it in as you do the nuts up would work at least?
Edited by Bl4cK32
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
