Canberran SAU'ers be proud! Get your butts to whatever newsagent sells High Performance Imports for Issue 67....Trust me:it'll be worth the read! Hint? Who ordered the foot-long with JUN,more JUN and topped with JUN special sauce? Another hint? Try the cover on for size...:
So;any ideas yet?Hmm?Hmmmmmm?!?
I was in a half decent newsagent today, and I didn't see this issue?
Is it out for subscribers only at the moment and comes out for sale in a few days?
Sorry, my bad. Yes,I've been a long term subscriber,and I do get issues a bit earlier than the newsagencies. Keep your eyes peeled:it'll be worth the wait! Oh,yes:VSR33,you're a smartarse...lucky you're a funny one,LMAO! (Actually,that Evo is quite horn.It's just overshadowed by a much nicer R32!!)
don't forget it's out tomorrow go buy it people >_<
Also i would recommend getting Zoom isue 99 it features bu5ter from SAU without doubt one of the best overall 33 gts-t's kicking around.
http://www.skylinesaustralia.com/forums/in...opic=94295&st=0
yeah i hit up every newsagent between belconnen and woden and i still haven't found it. most places have the last issue or no issues at all. i need something to read tomorrow when i sit in the emergency department trying to get my hand reset!
