hi boys and girls
i am just wondering what big hp skylines are using when it comes to automatic gearboxes.
i have got to the point where my strengthened toyota box cant handle it any more.
i am being pushed towards an al's race glide C4 or a power glide. i still drive the car on the street a fair bit but not more than 4000k's per year. with the new engine i intend to build it will make approx 900 at the crank so it has to be able to handle that sort of power.
any info would be appreciated.
https://www.sau.com.au/forums/topic/116996-automatic-trans-on-drag-cars/
hi boys and girls
KEAS.COM.AU SAY EDDY REFERED U BUSTER AND I BOTH USE 1,JPC BRESIANI,RAJB AND ALOT OF BHP CARS USE KEAS
I received the following email from Keas about a week ago:
Thanks for your enquiry. We will get back to you within 24rs to confirm order or answer your query. [email protected]
Haven't heard anything since and they don't list a phone number on their website. Guess they have far too much work to bother.
Adrian
If you are going to drive on street I wouldnt recomend a 2 speed, especially on a smaller motor with a turbo as there is no torque to get the car to moving when off stall and you will hate that around town trust me.... For that much power a c4 might be okay, keas can build you a killer jatco that will take it, personally th400 are my fav 3 speed, but you will probs have probs adapting the thing and it will cost a bit, just ring keas they will sort you out, alternatively if they are too busy try hugo's in melbourne, can build a tranny that bloke!!!
I didn't like what I heard at Keas so I ended up going to Mike at MV Automatics in Adelaide.
I honestly believe Mike is the most knowledgeable person with regard to Jatco's in Australia and discounting the engineers that designed the things right up there in the world. He gets jobs to do from all over the world (was building one for a Russian customer at the same time he was doing mine).
The only thing is, he's in adelaide.
phil cruickshank built my auto
i think pvl-747 is selling his glide its the same as mine as he isnt finishing his car pm him
hardcore have never worked on my car but they produce some nice cars
Edited by jas/slo32
Fred from Pro Trans in Southerland builds our autos. Built C4 in our Gallant, Builds a mean Powerglide also.
Should give him a bell, excellent bloke, will advise you on the best way to go.
9587 9594
hi boys and girls
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
