  • Replies 513
Posted Images
Yep, I had a ball... after snapping a wheel stud on my FIRST LAP! :)
After that drama I managed to fit 23 laps into the afternoon and got a best time of 1:15.9!
Big ups for Steve and Adam for organising the day. It was a shame about the hiccups regarding water and power and keys etc, but it was a great weekend all the same! Nice to meet some faces I haven't met before too!
Cheers!
Where your photos at Corrinne?
Lol.. whats email do you want me to send them to.. i have a few movies clips as well.. i will be uploading them later.. and i will post up links
Haha stan i have photos of your lil pet in there :)
Cheers!
you poor thing! But a top effort cutting a 1.15 with very little practice you had on that track! Well done!
Well done to Dave and Ando 1.13 and 1.14 respectively... you legends!!!!
What a fantastic weekend! Well done to Adam and Steve for organising! :)
satanic @ optusnet.com.au - Thanks D_I_F
Also thanks to all the non-competitors for making the effort to come out and cheer the SAU boys and girls on!!! Great to see so many people by the wall each time we flew past!
I had an awesome time too!
Now I need a set of semis and more practice to cut my time down! What sort of time should I look at running on street tyres and stock boost/turbo. I managed a 1:18.2, kinda hoped for better. One of the guys from Renew suggested I should have been trying for a low 16 maybe even 15.
I was on street tyres and stock boost my car is nearly completely stock.. lol.. that was my first track day too..
but i was happy with my time.. hopefully looking to cut it down a few seconds next time :)
Thanks guys and gals for the kind words (and vic of course for the can :))
Also a HUGE thanks to the guys that took me for a few laps - and yes, ill get back out there myself asap :)
Here are some of my pics
Sorry about the quality, norm turned the quality down on my camera on the way down, i didnt realize and therefore the pics arent all the best.....
Also there are a few vids (turn sound RIGHT up :) )
You can really tell when the camera settings were changed
Video's
(will be up shortly, uploading takes a while)
more than a few seconds!!! :) i didn't see you drive, but i'm guessing confidence is the only thing holding you back! just mow those pesky boys down! :)
man I just check the time sheet again.. there are way too many good times to mention!!!!
Adam, Shaun and George.. nice work!
James (lingeringsoul) did a 1.19 .. first time on the track!
and Paul!!! Good times as always and thank you so much or your help!!!! Hopefully next time I'm out there I can knock another second or two off.... was very frustrating sitting on 1.19 and 1.20 for the majority of the day!
Thanks liz! Good to see you are making progress too! :)
Adam had a cracker with 1:13! I was surprised and impressed!
Lol.. for sure.. want to work of my braking skillz abit more.. lol..
I want to be up there with the boys :) i absolutely loved it and i think more girls should get into it :)
For those not 110% sure about the worth of semi slicks, in Shauns car, we were sliding all over the place, how he got that time with those tyres and suspension, i will never know. Paul on the other hand, cracked the 10's, and its clear why - the grip his car has is nothing short of astonishing!
Also the willingness to break their cars MAY have had something to do with it :)
Shaun spent about 2.5 hours replacing a wrecked hose that limited boost to only 7psi (down from 15), and Paul discovered he had broken one of his brake rotors clean in two!
Well done guys - fantastic times, cant wait for the next one!!!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
